Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer does maintain heat
Igniter glows and flame comes on after rest
  • Maytag Master
  • 3,740 Answers
I need a little help here. Your post.... "Dryer does maintain heat"
With the comment: "igniter glows and flame goes on after rest"
So far everything your desribed is most likely normal operation.
Are you saying that the "Dryer does NOT maintain heat properly?" AND that the flame cycles on and off way too often?
I will send this as a solution however.... if you need more help just reply to this post.
-- If you disconnect the dryer vent ducting and it works normally the ducting is clogged up.
--If it still operates the same with the vent disconnected then the dryer air passages are clogged up with lint. Use a crevice tool and something like a folded over metal coat hanger to clean up the air passages
--This can include the lint filter itself if you use dryer sheets. The filter will appear clean but will not allow airflow due to the dryer fabric sheet particulate build up on the filter. Wash it with vinegar and water then soap and water. Make sure to clean the air passages around the lint filter.
--If after all of the above the dryer is still doing the same thing check the airflow out of the back of the dryer. It should gently push a relaxed hand and wrist away from the vent outlet hole. If it does not and your sure all of the air passages are clean then there is a good possibility that the blower wheel has failed and is spinning on the motor shaft vs being driven at full speed.
Also if you respond and need more help please include all of your model number or confirm that MDE7400AY is the correct model number.
Thanks for choosing FixYa.
Kelly
Posted on Jul 16, 2010
Dryer starts, but does not heat up. Igniter ignites, but no heat. Gas to rest of house is operable.
Thier are 2 possible things causing it not to heat.
1) The flame sensor is bad..if the igniter glows BUT does not go off it will be the FLAME SERSOR that is the problem
2) the coils that open the gas valve are defective..If the igniter DOES go off but no flame it will be the gas valve coils
while i dont know what brand you have their are fairly unuvesal parts for the coils or flame sensor
Part#'s
GAS VALVE COILS 279834
FLAME SENSOR THAT FITS ON RIGHT OF BURNER TUBE WE4X448
FLAME SENSOR THAT FITS ON LEFT OF BURNER TUBE 338906
GENE
Aug 28, 2011 | Dryers
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
What to do when dryer runs but does not heat up
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse , coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer is tumbling properly,but not drying. there is absolutely no heat.
pop the cap on the front of the dryer an turn it on
if you see the igniter glow an the flame comes on wait an see if the flame stays on if it it shuts off like 10 sencds later,you have a block vent
if no glow or flame u got a bad thermal fuse
if it glows ,flame an shuts off like and then comes an goes u have bad coils...
good luck post some feed back thanks
Feb 01, 2010 | Kenmore Dryers
No heat coming from dryer
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 30, 2009 | Whirlpool Dryers
No heat, no flame, temperature based high heat
if the dryer doesn't shut off you need a new timer. have you replaced the igniter or glow coil? it needs to glow white not orange in order to ignite the gas.
Oct 11, 2009 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
50 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
