Question about Troy Garden
I have a 25 hp 54 in mower and need part number for fuel filter
    President:
  • Troy Master
  • 1,545 Answers
Maybe check Troy's website.....but you can use an over the counter fuel filter purchased at Home Depot, Lowes, even on Ebay they have plenty of um....your part will be overpriced online ( w/shippping charges).
Posted on Jul 16, 2010
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
How do I replace a pto on a john deere eztrak 445 with 54" hc deck?
Most have a bolt holding it on. And unplug electrial connection.
Sep 20, 2014 | Garden
What makes a mower lose fire?
need fuel, spark and air. Make sure air filter is clear. Best way to test this is leave it off while you try to start (or restart??). For spark, easiest way is to spray starter fluid in the carb. If it starts, you have a fuel problem. If you havent lately (or ever?), change the fuel filter.
Jun 19, 2014 | Craftsman YT 4500 54" Kohler 26 hp Gas...
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
I get a vacum lock on the fuel
sounds like you need a new fuel cap as its pulling a vacuum on the tank and not letting fuel flow! also double check thats theres no debris in the tank to stop up the outlet
May 04, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
43 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
