Question about Friedrich M18CE Air Conditioner
My air conditioner Friedrich w18c3e is leaking inside? what do I do
  • 6,918 Answers
Clean the drain out,and make sure ,if it is a window unit,that the unit is tilted enough towards the outside
Posted on Jul 15, 2010
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
How old is my Friedrich WallMaster WS08B10 Air Conditioner
The age of your unit can be determined from the serial number. You will find this serial number on the data tag located on the inside of the unit just below the control panel. If you will call the Customer Assistance Center at Friedrich, 800-541-6645, extension 260, they will be able to assist you with the age of your unit. Hours are Monday thru Friday 7:00 am - 6:00 pm, central time.
May 05, 2012 | Friedrich WallMaster WS08B10 Air...
Thru the wall air conditioner is leaking droplets of water from between the frame and the body
Your unit should be pulled from the wall and cleaned. Also Check with a level that through the wall sleeve that the unit sits in has a slight lean towards the outside and not inside.
Jul 05, 2011 | Friedrich Heating & Cooling
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Friedrich model ss12j10 --compressor does not go on. Any possible
the refrigerant leaks or the thermostat is not working. i also got the same same problem and have the thermostat replaced by a technician
Aug 21, 2009 | Friedrich SL24J30 Air Conditioner
Friedrich air conditioner
Less efficent. Can you manually close it ?
Jun 07, 2008 | Friedrich QuietMaster RS10J10 Air...
Friedrich qstar airconditioner
With the price of a/c today it would be better to replace it then repair it. there could be a leak in the system or a bad compressor.
Aug 16, 2007 | Friedrich QStar SQ07J10A Air Conditioner
Friedrich M18CE Air Conditioner Logo
103 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
