SOURCE: Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
SOURCE: copier does not print copy
this noise could be coming from the by-pass , because toner fall down pain in *** to take out. dale
SOURCE: sharp copier makes grinding noise
Contact your dealer for service. You may need to have mechanical parts replaced.
SOURCE: our copier is not copying anything. If you put it
Your copier scanner is lock. if you have a user guide then follow the instruction.How can unlock?and where. I know where is ,it is copier delivery side under scanner or copy board please moving unlock position
SOURCE: SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
