Question about Kenmore HE2 Plus Front Load Washer
I am unable to get the door unlocked. The machine will power on and start the cycle then it makes a noise like it is trying to lock the door then the power completely turns off. Have tried circuit breaker reset and the door will not unlock.
  • keb7150 Jul 16, 2010
    Thank you very much!
  • 6,784 Answers
HI. This will essentially be the cause of a failed door latch assembly(mechanism). The necessary actions are to replace this damaged device, asap. Once replaced, the unit will operate normally.
To unlock the door manually; Follow the instructions below:
First, you must unplug the machine.
Next, remove the lower front kick panel. You will need a star-head screw driver (six points), which you can get at your Sears store. It requires a fairly small unit. I used an interchangeable handle with swappable parts to match the right size head.
The three star-head screws are located along the bottom of the kick panel. If the washer is sitting on the optional pedestal, be sure to pull the drawer out before proceeding. Then unscrew each of the screws and place in a plastic bag to avoid losing them.
Now at this point, the front panel is attached by pressure to the rest of the washer(retaining clip inserts). Take a crowbar or any slim tool to pry open the panel. Cover the end with a thin paper towel to avoid scratching the paint on the washer; Insert the thin end low in the gap between the washer and the panel, and gently twist until the side pops off. Do both sides this way.
Once the panel has been removed, look to the right on the side of the inner wall of the washer. There you will find the lost manual pages intended to help the tech interpret error code and fix conditions. It also contains instructions on how to (((UNLOCK THE DOOR))). Take the manual pages out from behind the plastic envelope (they are taped and sealed, be careful not to tear them) and put them with the rest of your user literature, where they belong.
You can now see the inside of the washer. Look up in the inside where the latch for the door closes. You will see a small plastic black box. Pull the bottom end straight down. Then, open the door. This procedure will allow you to gain access to the contents or manually drain your washer when this error occurs.
NOTE_ If you did not receive an error code during this ordeal, this will lead to a failed control sector. Normally when the door mechanism fails, the error code(FdU) should appear on the control panel. If this did not occur, your main CCU has failed.
Posted on Jul 15, 2010
GE front load washer model WCVH6260HWW unlock light stays on, machine won't run
Possibly need a new latch assembly per the suggestions at the link below:
https://www.repairclinic.com/PartDetail/Door-Lock/WH10X10006/1168668
https://www.justanswer.com/appliance/38tio-front-load-washer-reads-door-locked-model-xxxxx-when.html
Question asked many years ago:
3/11/2010
Appliance Technician: Tyler Z.
You will need to remove the lower front panel. There are 3 screws along the bottom. Remove these screws and remove the panel. Next, pull the plastic pull tab on the bottom of the latch assembly to manually unlock the door latch and then shut the door. Then start a cycle and cycle it to see if it will unlock on it's own. If not then you need to replace yoru door latch assembly. Here is a link to the part.
CLICK HERE
Tyler Z., Appliance Doc
Category: Appliance
Satisfied Customers: 87,538
Experience: 9+ years being an appliance technician with factory training.
We tried this and it did not release...is there anything else we can do?
not really unfortunately, you can try holding the door switch button in and try to start and cycle a cycle but I'm not sure that will work either, it sounds like you might just need a new latch assembly.
Does the latch have an actuater that would buzz or make a weird noise during a cycle?
not really no.
Front Load washer reads door locked model wcvh6260hww when
Jun 09, 2018 | GE Washing Machines
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
Immobilizer light will not go off when key inserted, Lock smith said my computer was not responding, Toyota wants to replace computer but that's 1200 bucks and I want to make sure that this will fix the...
YOU MUST HAVE MASTER KEY:
Sep 18, 2013 | 2001 Toyota Land Cruiser
Wfw97hexl0-door is locked and won't unlock or run a cycle just makes a buzzer noise every couple of seconds.
did you try to press the stop button then change the cycle to another then press the power button then press and hold the start button again that works most of the time.
Mar 11, 2013 | Whirlpool Duet WFW97HEXL Lunar Silver...
My watch was accidentally put in the washing machine. The cycle had started before I realized it. I have tried to open the door however is locked and will not open. How can I get the door unlocked so I can...
Pushing the pause / start button will unlock the door in all but the sanitary cycle. If in sanitary cycle, you may have to turn off power, then turn power back on.
Mar 17, 2011 | LG Washing Machines
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Maytag Neptune Front Door Load, Problem
Hello Yery1975
Welcome
You said, you have a situation with my washer machine (Maytag Neptune front loader). It was making the noise several times as latching the door, then if would go off and you could not open the door, You found the under soap deposit cord but the situation is not opening the door or no, it is getting he machine to work. Whichever cycle you press, the door makes the locking noise several times, sometimes the door can not be opened and the lock door light is off, the thing is that whichever cycle you try the numbers on the electronic pad would go down several numbers and then it will again make the door locking noise and will stop there, the start button begins flashing and the machine does not wash at all on any cycle, neither it spins or rinses. Can you please, please, help me? Ohooo... some times after trying and trying get the FL code... you have tried keeping it disconnected from the electricity for long periods, plugging it back and all you can think off.... but nothing!!!
You did the right thing
The Maytag Neptune had a lot of very different defects that Maytag was, and is aware of still.
That is why they discontinued that model .
But if you call Maytag service this time, you may find that it will be one of those defects in their design and an authorized Maytag person will recognize which fault is taking place.
perhaps they may cover the parts if you bring it to their attention.
Thank You
Please remember to leave a rating
Oct 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
