Question about Maytag Neptune MDE5500AY Electric Dryer
How do i get the top off to replace a belt. - Maytag Neptune MDE5500AY Electric Dryer
  • 375 Answers
You don't need to remove the top.
Open the door, find 2 screws holding the door hinges, remove screws; remove the screws on the opposite side of the door opening from the hinges. With the door open or removed, pull the front panel forward. the top of the front panel will separate from the case and you'll be able to remove it lifting it off the bottom. You'll see several screws with hex heads on each side of the case, which were behind the front panel. Those hold the top and support for the drum. Remove serws. Enjoy! ;)))
Posted on Jul 15, 2010
How to get inside and replace belt on washer model fws445rbs4 serial xc72602766
To replace that belt,use a flat blade screwdriver and place it between the top edge of front panel and top at the corners and pop up the top,raise the top,inside of the front panel at the top inside corners will be screws that hold the panel to the cabinet,remove those screws and push down and pull off front panel. To replace belt lay on the floor and grab old belt and rotate it off of the transmission pulley and pull it out,place new belt around motor and idler pulley and rotate it around the trans. pulley in a counterclockwise direction
Gene
Aug 10, 2011 | Frigidaire Washing Machines
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Belt needs replacing
Tip the washer back and the belt is underneath, just pull of and replace - simple.
Dec 29, 2009 | Admiral AW22 Top Load Washer
I need to raplace belt
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 19, 2009 | Dryers
Belt/Drum Noise
Jun 15, 2009 | Asko T761 Electric Dryer
Repair book for Belt replacement Roper REX5634PQO
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Roper REX5635E Dryer
SOUNDS LIKE A BELT IS BREAKING AND HITTING THE INSIDE OF THE CABINET
Remove the top sheet metal screws at the top rear of this unit,,then pry up the top,,,back to forward!!!,,,then have a look at the belt,,,,Replacement cost of belt usually around $12
Jan 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
