Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
I have a Frigidaire Side-By-Side refrigerator Model #FRS26ZSHB3, that is collecting water on the bottom of the interior of the freezer side. I have to remove the ice every 2-days, otherwise the water leaks out of the freezer. I have tired turning off the ice maker. What is wrong and how do I fix it?
  • 375 Answers
Drain system is clogged.
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
Posted on Jul 15, 2010
Frigidaire Professional 22.6 Cu. Ft. Counter-Depth Refrigerator - Model: FPHC2399KF I have ice that is collecting in the bottom of my freezer. My understanding is that this ice is caused by a buildup...
There is a chance that the drain hole is pluged or clogged with frozen ice.This can usually be cleared with hot water to melt the ice then dry off any remaining water with a towel.
the drain is located in the bottom rear of the freezer cabinet just behind the panel with the vent holes
Jul 06, 2010 | Frigidaire FPHC2399KF (226 cu ft) Side by...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Water leaks on the floor. i Is there a tray that
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Nov 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water collecting at the bottom of the freezer. Seems to be comming from vent that protects the coils. I think I have a blockage some where. It's a side by side Frigidaire model FRS24WNGWO with an ice...
your drain hole under your evaporator has some kind of restriction. remove rear panel in freezer section and look for drain hole. take a hanger and unravel it and poke it through the hole
Jun 21, 2009 | Frigidaire Refrigerators
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire side by side refrigerator problem
is it coming from underneath or out of the units refrig or freezer bottoms ??
Jan 26, 2008 | Frigidaire FRS26R4A Side by Side...
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Sep 26, 2007 | Frigidaire FRS26R4C Side by Side...
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
379 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
