Question about General Electric APE08AK Portable Air Conditioner
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear to be froze up and the filter is clean. It has been about 4 years since it has been used. Does it need freon? Thanks Bill
  • 57 Answers
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Posted on Jul 16, 2010
Testimonial: "I will double check the coils, but it appears they are clean. I am not sure about the fan and don't really know how to check it. Thanks, Bill"
Did you find what was wrong? My ge unit has just started doing the same thing. The coils are clean and the filter is too. It runs for about 15 minutes and then goes into fan mode for 5 minutes blowing out warm air. It no longer disperses any condensate out the hose into a bucket anymore. All of this has been happening for the past 2 days.
Posted on Jul 03, 2012
  • Tony Jun 30, 2013
    I had same problem. I cleaned off filter and dusted and wiped the coil good. Then unhooked the lil wire that is either the coil or temp sensor and let it hang there. When I say unhooked, its not disconnected just freely hanging. Works perfect again.
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
Ge refridgerator model sts16abserww, stopped cooling, down at the compressor I hear a slight click then wait a few seconds and hear another click (NO buzz between clicks), then wait a few minutes and the...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Refrigerators
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
My ac is running but its not cooling off the house.or its just not kicking in right away..what to do?
mcdevito75 Here, Try this, turn the a/c off completely and un-plug from the wall outlet for 5 minutes. Plug back in the wall and just put the a/c fan on for 5 minutes, then turn the control that says cool slowly to it's coolest positon and see if the compressor will kick in, if it doesn't you may need a charge of freon, if the compressor does kick in slowly back off the cool control to where the compressor just turns off. Contact any a/c repair shop in your area they come to the house.
Sep 01, 2010 | Heating & Cooling
A/c runs cool for about 20 minutes and then does not cool anymore. keeps running but does not cool.
Is the compressor still running or has it kicked out? The normal problem is that the unit is low on freon and the compressor is not cooling because of this. If the compressor is kicking off an feels hot to the touch but the inside coil is sweating when the compressor kicked off the compressor is going bad. On an outside chance the thermostat can be going out if you turn it to off or all the way down you should hear an audible click and again when you turn it up normally its good if the click is audible. good luck
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
Not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Dec 17, 2009 | GE Profile PSC25PSWSS Stainless Steel...
Blower in house runs, but compressor outside does not
Sounds like control voltage problem. Tsat mat be bad. It is hard to say without looking. Next time this happens. Have someone stands out side by the unit to see if the contactor is pulling in. When you turn the Tstat off and wait and turn it on you may be manually make the contact in the Tstat. If the fan and compressor are not running when you call for cool, Most of the time it is the control voltage. Let me know if the outside fan runs and the compressor does not. Rusty
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
General Electric APE08AK Portable Air Conditioner Logo
400 people viewed this question
Top General Electric Heating & Cooling Experts
Donni Steen
Bill Long
AJMAL KHAN
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
