I have a Legend L1928 LCD tv, we plugged it into cable, did the channel scan, when it said 100% we tried to change the channel and it goes to 1-1 on a blue screen, then black screen, makes a slight pop sound through the speakers and does it all over again, about a 5 second loop for this. Won't let you do anything with remote or on board controls and have to shut it off by unplugging it.
  • mmbrassfield Jul 15, 2010
    Is there any reset or anything I as a user can do? Can I check the lamp? it does show blue screen so think the lamp works and its LCD just to make sure that was known.
  • 4,889 Answers
Does the sound remain normal during this except for the pop sound?
Posted on Jul 15, 2010
  • 2 more comments
  • mmbrassfield Jul 16, 2010
    No, there is no sound other then the pop, which is like it is changing from one input to another, not to loud, but no other sound at all.
  • eagle338
    eagle338 Jul 16, 2010
    Looks like time for a new Main audio/video board? There is a small processor kind of thing on this board that is called EEPROM. It controls literally every thing related to video and audio(apart from timing control) not to mention the functions as well. Seems like it is fried and that seems to be the source of the problem. Unfortunately it is embedded into the board and is assembled by robots. Hence replacement is impossible. The only way to fix would be to replace the entire board.
    With this being a tv for my travel trailer, and actually pretty small, sounds like it may be better to get a new tv for the price of fixing this one?
  • eagle338
    Yes that sounds like a good idea. More so coz the prices have come down drastically!
  • 484 Answers
There is likely two(2) sources to the problem you are having with this television. 1) is the lamp and 20 is the t-con board.
Have a repairman run a check on the t-con board and the lamp to detect the faulty component and replace it.
Once you have them checked and replaced, the television would be in good condition again.
Take care
  • 1 more comment
  • ladipo sarumi
    ladipo sarumi Jul 15, 2010
    Sure, i know its an lcd tv, you can check the t-con board of the tv, to see that if it is working perfectly.
    As an expert i will strongly recommend you have a repairman check this as it is quite sensitive and needs a careful and thorough check.
    I hope you understand and fond this assistance helpful.
    Take care
    So with this being a smaller tv and used in my travel trailer, cost wise am I better to just get a newer tv instead of fixing this? I imagine the boards and the labor are not cheap?
  • ladipo sarumi
    ladipo sarumi Jul 17, 2010
    Sorry i replied to your post late.
    You are right it is quite uneasy fixing the television.
    A replacement will do just fine.
    But having it fixed by a repairman can also do the job.
    Take care
I have a 19 inch lcd isymphony tv and it keeps saying run auto channel scan. But I have no channels to scan for I'm in a barracks in camp Lejeune and we don't have cable here. I just want to use...
Tries unplug replug the tv like an hour later see if the tv reset it self back to factory mode setting it should stop this.Make sure tv is not on Cable,try Antenna setup just don't push for the scan function or yes answer.Tries used it with a HDMI cable for setup for the PS3 and used input like 1,2,3 so on this dosen't link to any airing tv stations functions.
Aug 09, 2013 | Televison & Video
Channel scan only finds 1 channel with basic cable setup on LG 42LD520
if you have a cable box just plug the cable box into a scart socket on the tv, switch the tv to the scart input and use the cable remote to change channel?Scanning for channels wont find anything because you are receiving the channels on a cable box. If you are refering to standard or digital tv signals and your not receiving any channels then either you are only scanning analogue tv and therefore wont pick up any digital tv channels, or your ariel is inadequate to receive an acceptable digital reception and will need to be upgraded. please state country you are in and what you are expecting to receive
Apr 13, 2011 | LG 42LC2D 42 in. LCD HDTV
I can only able to see 65 channels in my new samsung t.v[LCD]but in my calbe there are more tahn 70 channels....how can i see the all channels
When you scan for channels, make sure you choose "cable" for the setting under the "Antenna" tab.
channel --> antenna --> choose cable
This should let your TV show more channels. Most cable companies issue cable boxes now a days, which you plug into your TV. You usually change the channel by using the remote for the cable box.
Hope this helps
Mar 13, 2011 | Samsung LN26A330J LCD TV
I can't change the cable channels
Try the 991 code, press tv+ code set+991 then alternate between tv and power stop as soon as the tv respond then press enter , could take up to a 100 try since it goes thru all the codes. have fun
Nov 02, 2009 | Insignia NS-LCD19 19 in. LCD TV
Legend LCD tv power issue
the problem is inside th vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 mf 10 v capacitor . little bit of soldering/de soldering skill is needed . cost of cap 0 dollars got it from old radio. ernie
Feb 17, 2009 | Televison & Video
Element FLX 3210 not scanning for cable channels
YOU HAVE A BAD TUNER OR RF INPUT. IF YOU CONNECT THE CABLE TO THE VCR AND THEN USE THE VIDEO OUTPUT OF THE VCR TO THE VIDEO INPUT OF THE TV YOU CAN USE THE TUNER IN THE VCR TO CHANGE CHANNELS.
Jan 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Legend LCD LC1916L TV Picture
If you unplug the unit from wall plug for ten minutes, it should reset the picture. I would unplug the a/v cables also in case of a ground loop
Feb 29, 2008 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
