Question about Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
I don't know how to start self cleaning option.
I have pressed self cleaning button but to date nothing happens.
  • 677 Answers
Hi, Although some issues with Frigidaire gas ranges may be cause for a service call, you should try to first determine if the problem can be easily resolved. Some basic Frigidaire gas range troubleshooting can often solve simple problems or give you an indication of what could be causing the malfunction. Although different models of gas ranges from Frigidaire may vary, you can still perform these basic troubleshooting techniques.
Set the clock of your Frigidaire gas range. The gas range will not turn on unless the time is initially set. To set, select the "Clock" dial and arrow through the numbers until the correct time is reached.
Check that all of the wires of the Frigidaire gas range are connected in the rear of the appliance. If you notice a connection is loose, call for service.
Clean the burner ports of your Frigidaire gas range. Clogged burner ports will cause the burners to not ignite properly. Use mild soap and hot water on each burner after removing the grates. For a large amount of build up, oven cleaner can be applied. You can also run a self cleaning cycle for the oven portion of the range if you run into any problems. Choose the cycle from the digital menu on the Frigidaire gas range.
Press the "Cancel" key on the Frigidaire gas range if an error message appears on the digital screen. This should reset the controls and allow you to enter a new operation.
Re-power the appliance if the digital display is stuck and will not operate. Unplug the gas range, wait five minutes and then plug it back in. Set the clock and then try to operate it again.
Posted on Jul 15, 2010
How do I start the self clean cycle on my oven.
Is there a door lock handle? Lock it! All self-clean ovens must be locked before the unit will clean, if it is an automatic lock, the door lock motor might be bad.
Apr 24, 2016 | Ovens
Can't set the date/time on my fujifilm AV200 when i press the ok button to set it nothing happens
Press the MENU button and there will be a date and time option so just choose it and set it and press MENU again and Your Done
Sep 26, 2013 | FUJIFILM FinePix AV200 / AV205 Digital...
I don't know how to get/find/use the timer on my camera FINEPIX SL245
Press cursor-down (marked with a one-handed clock) to bring up the self-timer menu, use cursor-left/right to select the desired delay, then press the MENU/OK button. Start the self-timer by pressing the shutter release button as usual.
Full details are in the "Using the Self-Timer" section of the manual (page 39 in my copy). If you need a manual you may download a copy here.
Jan 28, 2013 | Cameras
Front loader hotpoint wf840 running 'test' cant remember how to reboot. last time i had to do this i had to hold down one of the buttons for a few seconds and wait till a specific word came up on...
Here are the instructions to (just) clear the 'test' depending on the date code:-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to norma
l
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
I have an admiral self-cleaning oven in my apartment and do not know how to turn it on! I have locked the oven and pressed the clean button, but nothing happens. Help!
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Apr 23, 2011 | Ovens
Model #GJSP84902 I turned on the self-cleaning cycle and then immediately pressed off. It said END & locked. Then the message E1-F5-locked is displayed on the screen. I tried pressing all the...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 04, 2010 | Whirlpool Kitchen Ranges
I have lost my manual and do not know how to clean my self cleaning freestanding electric range. I press the clean button but nothing happens
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Self cleaning oven
Press the cleaning button and then the up arrow that regulates the temp as if you are baking I think it reads 300 and then it starts. This is for Kenmore self cleaning
Dec 10, 2007 | Magic Chef CER1115AA Electric Kitchen...
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
69 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
