Question about Acer Aspire One PC Notebook
Wont boot up
My lap top's battery was drained so i recharged it full but now it wont boot up.
  • detour342
    detour342 Jul 15, 2010
    Have you tried taking out the battery and only use the charger see if it will boot...if so shut it down unplug charger and reinstall battery try again
  • 127 Answers
Take battery out put it back in and try turning it on again if that doesn't work your battery might need replacing
Posted on Jul 15, 2010
I have Motorola Bluetooth H730 and it wont take a charge anymore
Rechargeable batteries fail after a maximum number of deep-cycles. Letting the battery drain completely before recharging, will shorten it's lifespan compared to keeping it topped up frequently.
Replacement batteries can be found on Ebay and elsewhere.
Jun 17, 2017 | Motorola Radio Communications
I have a Compaq M700 lap top. power failure , Won't boot up ?
You need to find out if the power supply was damaged, it would have been the first to take a hit, remove the main battery to see if it will boot because a bad one will load the system down in some cases. One trick that might work, unplug power supply from laptop and remove main battery, now press and hold power for 2 minutes to drain off residual voltage and reset the processor, finally install everything back and power up.
May 03, 2012 | Compaq ARMADA M700 PIII500 MHZ LAPTOP...
My acer aspire 1-zg5. I uninstalled the microsoft security alerts and since it wont boot, it gets to the 'press f2' bit but thats it. it wants me to install something and press 'r' for...
Hi fhuseyin,
The easiest way to correct this issue is by performing a power drain. Please follow the steps below.
1. Turn off the system.
2. Unplug the AC adapter from the the power outlet.
3. Remove the battery from the unit.
4. Now, press the power button for about 15 - 20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Turn on and observe the system.
Hope it helps.
Thank you for using FixYa.
Aug 16, 2011 | Computers & Internet
Our lap top wont turn on, the battery is reading 25% power, but ut wont turn on even plugged into the wall. i get a read sensor light when trying to turn on
remove the battery and plug into wall try booting and see if it boots up. if so you need a new battery. if problem continues feel free to contact me
Nov 13, 2009 | HP Pavilion dv4000 Notebook
Got power, frozen machine
okay what you need to do is if you have the system restore cd use that , it will reformat your lap top even if it cant reboot just put in the cd when you start up the computer and it will restore everything you may lose alot of things but atleast your lap top will work after , if not then Reply to me at Jonk3y at Aol.com and i will gladly help you with your problem
Sep 23, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
Lap top switched off and now wont switch on,
boot from CD need the OP SYS or recovery disk that came with the computer
Jul 28, 2009 | Fujitsu AMILO PC Laptops
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
My lap top shuts it's self on am off
Try removing the battery and starting up only on AC power. You may have a faulty battery. It could also be the power supply or a bad memory chip. If it's none of these, then it's a motherboard problem.
Jun 20, 2008 | Compaq Armada E500 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Lap top battery dead?
Probably the extreme heat and dryness out there drained it out, and or not being able to recharge it to full capacity. Did you charge it the recommended hours to charge when first used as stated in the manual the battery?. If you have access to a freezer put the battery in a ziploc bag seal and leave in the freezer overnight then take out and charge your battery overnight it might come back to life and hold it's charge once again.
May 04, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire One  PC Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
