NEED HELP HOW TO CONNECT MY PRINTER TO PC. iT WON'T DETECT THE PRINTER CABLE...
  • 942 Answers
I guess your printer is not a network printer, meaning it is not automatically connected to your router if you have or it is using a dedicated internet connection thru your internet provider in which I believe you have. You may install a USB adapter in which this adapter will be connected directly to your modem or your router. And then this USB adapter has its port dedicated to printer. One end of the port is connected to the printer and the other to the adapter itself. You may install this once you connect this adapter thru one of the USB ports. Otherwise, if you only have one cable connected from your computer to the printer, then you may check the device manager by clicking Start > right click Computer > left click Properties . Then click Hardware and then click Device Manager. Check if there is Printer devices installed such as USB adapter or any other drivers in particular.
The important thing here is that printer cable should be detected, you may reinsert the cable after you turn off the printer. If you have another printer cable, try to test if it works. Otherwise this might be a compatibility issue with the printer and the pc. That is time to refer to your printer manufacturer.
Again, these steps are the suggested ones, you may consult a technician if symptom persist..
Posted on Jul 15, 2010
My printer is not printing showing offline
First thing you need to do is power cycle the printer. If that doesn't fix the problem then restart your PC. If it still shows offline and you used a USB cord to connect to the PC, I would try changing out the USB cord. If it is a wireless printer, then you need to log into your wireless router and see if it shows an IP assigned to the printer. If not then go thru the wireless setup routine for the printer again.
Feb 27, 2018 | PRINTER Office Equipment & Supplies
Error message 3
Please follow the following steps.
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer connects to the PC.
(4) ***
5) Now, reconnect the USB/Serial cable and switch ON the PC (only PC and not the printer).
6) Let the PC boot up and login to windows.
7) Now, switch on the printer, PC should detect the printer automatically now.
Dec 05, 2011 | Office Equipment & Supplies
I have a toshiba notebook. how do I set it up to my printer
you will need to connect the Netbook to printer using either USB or Wireless(if this feature is available in your printer).... most printers these days can be connected using USB cable.. after connecting you will need to install printer drivers on your netbook... and after installing drivers your netbook will detect your printer and you are ready to go!
Apr 10, 2011 | Toshiba Satellite Pro L300 Notebook
How can connect with computer?
plug in your usb or parallel cable from the printer to pc.. then install the driver.
Switch on the printer to see if the pc can able to detect .
May 30, 2010 | Epson Stylus Color 440 InkJet Printer
The printer won/t connect even with a disc
if the printer wont connect to your desktop or laptop but has power, changing the cable would be posible, or check the integrity of the ports that you are connecting, if a desktop or laptop does not detect the printer it only means that you have a bad printer cable
Nov 21, 2009 | Computers & Internet
The scanner suddenly stopped working - the error
try turning it off and on, if this doesnt help un plug cable and restart PC.
then plug cable back and and see if the PC will detect it then try again.
if the PC doesnt detect it then try different cable and if this doesnt help you will need to contact manufacturer.
Oct 31, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
How do i connect to a laser jet 1020 dell
If the printer is new out of box then remove the printer out of the box with the Data cable and the power cable with the disc.
Connect the power cable from the printer to the power jack.
Connect the data cable from the printer to the USB port in the laptop.
Once this is done turn on the printer.
The system will detect the printer and a dialog box prompts the installation of the printer.
Then put the DVD on to the drive and from the dialog box choose the location as the CD/DVD drive as a source from where to install the software. This will install the printer and the printer is ready to use.
else
install the contents of the CD/DVD by accessing and double clicking the drive directly.
Sep 16, 2009 | Dell Inspiron 1525 Laptop
Need help on printer startup problem
did you uninstall the driver?
when you hook your cable to USB port, you pC should detect your printer. Try to cycle power your PC and try to hook your cable to another USB port after you uninstall the driver
Mar 21, 2009 | HP PhotoSmart 7350 InkJet Printer
I ve just bought lexmark z2300 printer, how do i connect it to my laptop which is on wireless broadband with perlico? ta caroline.
You need to connect the printer with an extra cable which can join it through its 25 pin parallel cable. That cable then with USB end connect with the Laptop. and its drivers can be automatically detect by your Vista system.
For Vista 64-bit, the driver for printer and cable should be digitally signed.
Otherwise you need this method for Driver Installation in Windows Vista 64-bit:
The 64-bit version of Windows Vista is the first version of Windows that will only allow signed drivers and this restriction is built-in. For most cable drivers are unsigned and we request you to follow some prerequisites before installing the driver.
Preparing Vista 64-bit for Driver installation:
  • Using the F8 option: Press F8 key on your keyboard while booting your PC. You will get into “Advanced Boot Options”. Select “Disable Driver Signature Enforcement”
  • An F8 Advanced Boot Option introduced with Windows Vista—“Disable Driver Signature Enforcement”—is available to disable the kernel-signing enforcement only for the current boot session. This setting does not persist across boot sessions.
  • Note: Make sure to use F8 option every time you boot/reboot your PC before start working with MCS77XX.
  • Make sure that the User installing the driver must be a member of the Administrator group on the system.
And for printer driver if you dont have CD then go through this link and follow the steps:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Let me know if you need furhter assistance, I will help you to run your Printer with Laptop.
Regards,
Ellin
Oct 16, 2008 | Computers & Internet
Need to connect printer to pc, x4270
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=x4270
If you don't have the driver follow this link and select your operator system(OS) and download it.....if you do have the disc install the disc in your PC and install the driver (important : do not connect your USB cable to your PC until it prompt you to do so) When you'll connect the cable to the PC windows will detect a new hardware and will procede to the installation.....
hope it help you !
Apr 16, 2008 | Office Equipment & Supplies
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
