Question about Whirlpool MH3184XP Microwave Oven
Microwave won't cut off just keeps going. The turn table turns but it stops mid-way thru the time set and won' turn but you still here the sound like it cooking.
  • suptretired Jul 15, 2010
    Yes the solution was helpful.
  • 677 Answers
This could be a failing turntable motor, but more likely your turntable support has gotten bent. That's an easier and cheaper problem to solve.
Excessive heat can sometimes make the legs of the support bend so that the center is raised up far enough that it won't always make good contact with the motor.
You can test this by running the microwave empty for a few seconds. It may hesitate to turn or stutter.
Next try it with a bowl with several cups of water in it. The extra weight may push it down so it makes good contact and runs without a hitch.
The way I fix these is to use a stove burner or a torch to heat up the legs and bend them up a bit.
Then I quickly set up or clamp the support so it's held in the proper position for a few minutes until it cools.
One way to hold the heated support in position is to place an object under the end of each leg and put something slightly heavy on top of it in the middle.
If you need a new motor or just want to see helpful exploded views of your model, see the GE or Sears parts Web site:
http://www.geappliances.com/shop/prts/
http://www3.sears.com/
Posted on Jul 15, 2010
Sharp carousel 1200 watts microwave manual
They is one of the DOOR SWITCH need to replace
Aug 17, 2014 | Sharp R-1480 Microwave Oven
Problem with KHMS1850S Stainless Steel 1000 Watts Microwave Oven
Possible that the Magnetron is powered off or is defective. You can check the main capacitor to the HT, check the leads, check the main board.
Also check the sensor which is mounted on the top or side of the cabin which is protector for overheat and can cut the voltage for safety.
If so also check the wave guides
Click on: Waveguides
Jan 30, 2013 | Microwave Ovens
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Turn table on microwave won't turn - Model FMCB115gm
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 24, 2011 | Frigidaire Mid-Size Microwave
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Frigidaire microwave doesn't work
Don't have a fix for your problem, but my Frigidaire microhood just did the exact same thing--about the same age, started cooking some food and it worked for a few minutes and then just stopped--time kept going, light stayed on, but turn table stopped and fan noise cut out. I tried it a few more times and it seemed to fade in and out and then stopped trying.
Nov 30, 2009 | Microwave Ovens
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH3184XP Microwave Oven Logo
24 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
