Question about GE GSS25JFM Side by Side Refrigerator
Door handle replacement on GE GSS25JFMC refrigerator
How do I replace door handles on a GE model GSS25JFMCWW refrigerator?
  • 29 Answers
SOURCE: GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Posted on Oct 30, 2007
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
SOURCE: GE Side by Side refrigerator door handles yellowing
I have tried everything to clean these handles. This refrigerator was a piece of junk from the onset. The fan on the ice maker has had to be replaced twice and the motor once. The ice maker has always leaked and frozen. This was extremely disappointing and I will not be buying GE products again!
Posted on Apr 05, 2008
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
  • 8 Answers
SOURCE: can't get the refrigerator through the door ; how to remove handl
When I brought my side by side home,I had to remove both doors. I also had to remove the entry door AS WELL as the door center jamb!! Removing the refridgerator doors is really not a major task!
Posted on Nov 20, 2008
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
Remove door handles
Search Results
    Refrigerator Door Handle - How To Replace - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=O5q0WhxMfmQ
    Sep 17, 2012 - Uploaded by AppliancePartsPros
    Follow these simple step-by-step instructions to replace theRefrigerator Door Handle on Whirlpool, Maytag ...
    How to remove or take off Whirlpool fridge door handles ...
    ? 2:22
    https://www.youtube.com/watch?v=tmYz4FVqVnw
    Oct 3, 2014 - Uploaded by way22good1
    How to take off whirlpool refrigerator door handles. ... How To Fix Your GE Refrigerator Handle by removing ...
    Whirlpool Refridgerator Door Handle removal - You
Dec 20, 2015 | Refrigerators
GE model # GSS25JFMCWW has water to the dispencer,but not to the icemaker.
could be a number of thing,s The device that sends water to the ice/mak is different than the door water the ice maker has it,s own brain (circuit) water in/out some built into the frig itself . The ice /mah send siginal to water valve to send water.. to ice maker sorry icall appl man sorry
Mar 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a GE side by side Model No. GSS25JFMCWW. The refrigerator side is not staying cold. When I remove the back panel in the freezer there is heavy frost build up on the coils. If i thaw out the coils...
the ice disp stopped working now the unit will try to start then stop over and over, went to main board on back of frig. took off jumper one connector it stopped but not sure what jumper one controls
Oct 26, 2010 | GE GSS25JFM Side by Side Refrigerator
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have broken handle on the GE Spacemaker Model JVM130H. Can this be replaced and how?
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number(s) for a replacement door handle is WB15X10119 and WB15X10120. The door handle on this model has two pieces.
If you have any questions, please post back with your model number and let me know. I hope this helps you
Jan 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
GE GSS25JFM Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
