Question about Dometic Rooftop RV Air Conditioner
Fan runs then compressor kicks in. instant 66 amp draw,clunks and shuts down ??
  • 456 Answers
Sounds like the compressor is seized up or starting to. You could try a hard start kit to give it an extra boost and maybe it will snap out of it.
Posted on Jul 16, 2010
Compressor building heat on portable air conditioner 200 degrees shuts down . anyway, to make run cooler ? fan to outside IS functioning ..
The issue with overheating can be caused by many things.
1. Lack of refrigerant
2. Internal wear on the compressor
3. Inadequate air circulation on the condenser
4. loss of viscosity in the oil
5. Voltage issues.
IF this is a portable unit, they are sealed and cannot be serviced with conventional equipment. The ports for checking the pressures etc are crimped and soldered. Make sure all the coils are clean, the fans are working and running in the right direction.
Jul 30, 2018 | Heating & Cooling
Kyd-25 compressor does not turn on.
with a meter you could test the amp draw on the compressor but it sounds as if you are drawing l.r.a.. This is locked rotor amps, a rating you could likely find on the data plate of the machine but ultimately means the compressor is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 19, 2018 | Heating & Cooling
I have a carrier outside unit 38YKB036310 unit It comes on & cools but after around a half hour it shuts down. The fan motor feels hot I replaced it (the fan motor) & still have the same problem.
does just the fan motor shut down and you can hear the compressor still running when this happens?
did you replace the running capacitor for the new motor? is the motor a compatable replacement? how many amps is the motor drawing?amps should be close or under nameplate rating? is the outdoor coil clean?did you reinstall the fan blade the same depth as the old one?do you have the proper voltage to the motor?
Jun 21, 2010 | Heating & Cooling
Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
May 18, 2010 | Dometic Rooftop RV Air Conditioner
OUT SIDE UNIT SHUT DOWN IN HEAT MODE, WHEN YOU FIRST TURN IT ON IT RUNNS FOR ABOUT 30 SECONDS THEN BOTH THE COMPRESSOR AND FAN SHUT OFF FOR APROX 3 MINUTES {LARGE LINE STARTS TO GET WARM} AFTER 3 MINUTES...
Hi, You have a heat-pump, this I do no. The reason it is shutting down from how you have explained it to me, is the compressor is shutting down due to high pressure and it is going off on the internal overload. When the compressor cools down, it starts back up and runs again. As for the large line getting warm, this is normal for a heat-pump as in the summer this line will be cold. The reversing valve changes over the flow of freon and the flow goes in the other direction. Back to you're problem. The service tech is bleeding off freon because he is apparently showing with his gauges it is over charged? This will cause it to draw to many amps and shut off. Has this compressor been changed out recently? Or maybe freon added due to a leak? He is doing it because he is thinking it is over charged. It may be some if it runs for a few hours after it is bled off. Did you notice if he clamped his meter around a compressor wire to check the running load amps? If so, that's what he is doing. I would say this unit had work done on it recently or correct me if I am wrong. The condenser fan motor should not shut off with the compressor, it should run all the time even if compressor shuts off on internal overload, believe me!! The fan is wired separate from compressor. The only time this fan shuts off when heat is on, is when it goes into defrost, and compressor keeps running. For the compressor to run for only 30 seconds and shut off, and then back on in 3 min, on for 5 seconds and off again, sounds to me this unit is short cycling due to being under charged. It is strange it runs after he bleeds freon off for a 1/2 a day. As far as the fan shutting down to, and I would like you to get back to me, if the compressor was changed at some point, the fan wiring was connected to the contactor load side, so it shuts down when compressor shuts down. One fan lead is on the wrong terminal of the contactor. If this is the original compressor, this could have happened at the factory, I have seen this before. The tech should have seen this!! Going on and off this fast, would not cause the compressor to get hot enough to kick off and cool fast enough to come back on that fast! Sounds like low pressure. I don't like to knock other techs work, but this unit is not being checked properly. Without me being there to install my gauges and amprobe, all I can do is tell you he is wrong with his solution, way off. Heat-Pumps are much more tempermental then a split a/c only.What to do is call them back out and request a different service tech, or the service manager. This will be no charge to you! You should be reimbursed for the last call. E.P.A. allows us to only loose minimus amounts of freon installing our gauges also. It is forbidden to bleed it into the air. He could be fined $25,000 the 1st time!! It also sounds as though you have a problem in the defrost board that would cause this. Please call them back out and don't feel bad about it. This is you're right! Tell them about the fan also as if it is going off on high pressure which I think not, the fan would stay on. I know this is long but I want you to understand what is going on. I do this for a living and know whats up! I am a Licensed contractor in this field. Please keep me posted. I will be waiting to hear back.
Sincerely,
Shastalaker7
Dec 21, 2009 | Heating & Cooling
My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Sep 14, 2009 | Dehumidifiers
Fan runs with 3 amp draw, compressor comes on and draws 20+ amp, kicks out breaker, is compressor bad Tom
most likely compressor has seized but check start capacitor first if burnt out or just replace it with new one, it has to be replaced with new compressor anyway
Aug 17, 2009 | Heating & Cooling
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Fan quits and the compressor still runs
is this a split residential system. it sounds like you are talking about the condenser fan either way it seems like the fan is overamping and tripping on thermal overload which is a device in the motor that protects itself. when you shut it off for a while and turn it back on does the fan work. if you turn it off then turn it right back on does the fan work. when it shuts off is the motor really hot. if possible, and you know how, check amp draw. typically you can find the rated amp draw on the motor nameplate.
May 27, 2009 | Carrier 52CQ315 Air Conditioner
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
122 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
