Question about SanDisk Sansa m250 MP3 Player
My sansa player 2gb will not rechrage battery..MY
My sansa player 2gb will not recharge battery..MY USB is wroking/computer is running!
  • kakima Jul 15, 2010
    Not all USB ports put out sufficient current to charge other devices. Try plugging it into a different port, if available.
    Can you charge other things (digital camera, cell phone, etc) on this port?
    Do you have an USB charger that plugs into a wall outlet? If so, try that.
  • toy1975 Jul 15, 2010
    I have an nother Sansa player 4gb which is working just fine and will charge that battery BUT not my SANSA 2gb its started charging this am and when I removed it and put it back on it drainer what power I did have and NOW I cant get it to charge at all!!!!I have tried plugging it in different port...I dont have a plug into wall outlet!Dont want to run out and BUY since I know my port is working
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Unfortunately, I have to concur with adominicg, at least as far as to say that it seems like a bad battery.
Posted on Jul 15, 2010
Testimonial: "Thanks for the help!I was funnying with adominicg IF someone had $20.00 I can borrow to buy a new one!Will buy new one BUT with 4gb:)Again much thanks!"
    Master:
    Sergeant:
  • 383 Answers
Its a bad battery buy another $20 mp3 player
Testimonial: "You got $20.00 I can brought:)lol NOT really NOTHING else I can try!"
Can I recharge the battery of my Sandisk Sansa Clip MP3 player without using my computer?
Yes. AC to USB adapters are available anywhere cell phone chargers are sold. One end plugs into a wall outlet and you can plug the USB cord from your Sansa into the other end. I use such a device every night to charge my Sansa.
Aug 25, 2011 | SanDisk Sansa Clip MP3 Player
My sansa 4gb clip is not recognised by my computer. The computer will not acknowlege the usb either... My sansa has run out of battery. What can I do????
Hai, i have sansa clip 2gb with the same problem. one ultimate answer i got is Sansa clip uses Media Transfer Protocol(MTP). Sandisk(maker of salsa clip) know about the problem which cannot be solved(the earlier sansa products are to be avoided). There is no solution with the company.
Nov 15, 2010 | SanDisk Sansa Clip MP3 Player
Does sandisk sansa m240 have a rechargeable battery or can i recharge it thru the USB..
Hi There
For this issue i would say the best solution is, you can use the USB cable, thats the best solution rather than using the rechargeable battery.....
Feb 08, 2010 | SanDisk Sansa m240 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
How do i recharge my slick 2gb mp3 music and video
Like most MP3 player with an inbuilt internal battery, your Slick 2gb mp3 music and video player will have an internal Li-Ion rechargeable battery that will be recharged via your USB Data cable while connected to an USB port on a PC/LAPTOP or USB charger.
Dec 19, 2009 | Audio Players & Recorders
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Mp3 will not work
disconnect the USB cable and let the battery run down when the screen goes blank you can reconnect the USB cable and the device will rechange and you can do you thing
Jan 04, 2009 | SanDisk Sansa Fuze MP3 Player
Charging the battery on a sansa mp3 player
recharge it by plugging it in to the USB port. your sansa should have come with a USB cable and the ports are pretty easy to find.
almost all types of earbuds or earphones are compatible with the sansa system, so if you just go out and buy some you should be fine.
May 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Cannot charge or copy music onto the sansa e270
You might not have the battery "seated" correctly. Try removing and replacing the battery.
Sep 04, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
222 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
