Question about Oregon Scientific Electric PTO Clutch for Exmark and Warner
Blades wont turn a exmark quest sp model . The blades were turning when I first started cutting, then they stopped. The belts are new, they did not come off, large springs are still attached which seam to be maintaining the tension. What could be the problem?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Delta 36-600 table saw new belt run's and sounds great, BUT wont cut butter?? Any help would be great thanks. Oh could it be brushes?? Cheers Matt Blade is in the right way,Delta 36600 have brushes.
Not to insult your intelligence, check the blade direction. Looking at the tablesaw from the left side, the blade should be turning clockwise and the teeth cutting downward. Also the teeth should be very sharp. Typically a belt run tablesaw doesn't use brushes but a capacitor to start rotation. You didn't mention if the blade turns when started. Since you mentioned it sounds good when started I'd rule out the motor. Some saw blades have an arrow to indicate direction. Hope this helps. Good luck.
Oct 28, 2017 | Vacuums
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
My husband was mowing with an Exmark Quest riding mower and ran over an extension cord. It stalled and won't start again.
The flywheel is locked to the crankshaft with a aluminium key. If the engine is abruptly stopped this soft aluminium key will shear off and let the flywheel turn.The shaft quits turning and the flywheel don't. This is to avoid breaking the crankshaft. When the flywheel turns or spins on the crankshaft it puts the spark timing out of time and will not run, it might backfire or spin and stop or just spin over.
Jul 17, 2016 | Garden
Why exmark loses power when blades are turned on
Check for clogged deck.also inspection of mower deck belt. Check for glazing or cracks in belt. That will slow blades down.
Jul 28, 2014 | Kohler Engines NEW 25HP KOHLER ENGINE...
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
My Craftsman riding mower runs fine but when I try to cut thick or tall grass the blades slow down and stop cuting, I replaced the belt thinking the belt was worn only to find I still have the same...
well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Jul 28, 2010 | Craftsman Garden
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Oregon Scientific Electric PTO Clutch for Exmark and Warner Logo
431 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
