Question about Samsung DLP HL-P5663W 56" TV
Just replaced color wheel. Colors are messed up,
Just replaced color wheel. Colors are messed up, blue skin etc.
  • dtubbs671 Jul 16, 2010
    two video cables in the back were reversed. Fixed!!!
    Thanks.
  • Samsung Master
  • 8,457 Answers
Check all the connections again.U miss some connections or wrong connections.
Posted on Jul 15, 2010
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HL61A skin color is green
Need complete model #--to determie if this set uses an LED light source--if so--the red and blue LED';s have failed.
Mar 13, 2014 | Samsung HL61A750A 61" HDTV
My blue and green coloring is messed up on my Mitsubishi Medallion. I can't get it to have both colors normally, it has to almost be one or the other. Is this just a contrast issue, or something
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Oct 06, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
What are the signs of a bad color wheel?
Distorted colors, blurring of colors where multiple spectrums appear as another spectrum.
Mar 01, 2011 | Televison & Video
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
I installed a new color wheel in my 6167w 61 inch hdtv. Now my colors are all messed up. Like the reds and blues are backwards.
You must go into service mode and re-align the registers, if you've never done this you must call a qualified svc center. Most color wheel replacements require re-alignment. The DLP must match the speed of the color wheel.
Feb 26, 2009 | Samsung HL-R6167W 61" HDTV
Mixed colors
Color wheels in that unit were updated to remedy a flaw in their initial manufacturing. I suspect you have one of the updated wheels and now the dmd board is having a problem distinquishing relative speed etc. Pull dmd jumper to fix it. Remove the jumper pin on the dmd board, metal shield has a cut-out so you can just reach in and grab it with a pair of needle nose pliers and pull it out.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Nov 04, 2008 | Samsung HL-R6167W 61" HDTV
Samsung DLP HL-P5663W 56" TV Logo
193 people viewed this question
Jerry Greenberg
Jerry Greenberg
