Question about Motor Max 1964 1/2 ford Mustang Convertible Diecast Model Car 1:18 Scale Die Cast by Cream White 1 of 3064
Rear drivers side door not unlocking please can you give me some idea what to do I have put wd 40 into the lock - inside by the handle side of door and outside door handle this helps short term but after 1 hour of the car being locked again the problem is still there.
    President:
  • 2,702 Answers
Its the door lock "actuator" sezed up,,, take the door lining down and look at the door lock there is a kind of coil that pull the lock on and off that's "actuator" soke it with wd40 may help,,,but normaly when they play up you just change them
Posted on Jul 15, 2010
2000 Ford Explorer back door driver side door WILL NOT unlock
For this type of problem I recommend YouTube. Always a wealth of information on rear gates door locks etc.
Google > YouTube 2000 Ford Explorer door locks
Oct 08, 2017 | Ford Cars & Trucks
Drivers side door closed and will not open.
Remove inner door latch and try operating the rod manually (vice grips). If locked, spray everything inside the door with WD-40 or the like and try operating the lock.
Aug 15, 2016 | 2011 Honda Fit Sport
How does the 1999 Tahoe tailgate open?
The right side can be unlocked with the key, once opened, the left side can be opened. Mine, the left side requires me to push in slightly while ensuring the release handle is pulled to it's furthest point before it will unlatch. If the electrical contacts at the door frame are dirty, the door may not unlock when pushing the button up front thus requiring the key to be used in the rear door. If this is not the solution, the latch rods inside the door need adjusted which requires some mechanical expertise.
Jun 04, 2014 | 1999 Chevrolet Tahoe
Locked doors on '98 Toyota Camry. Locked out of car!
have you tried spraying wd-40 into door lock?
Dec 31, 2017 | Toyota Camry Cars & Trucks
2007 chevy tahoe touch screen radio will not respond to touch, everything else works fine.
If the electrical contacts that go to the rear door lock are corroded the lock/unlock switch will not work. Spray WD-40 (with the spray wand) from inside the truck into the space between the truck and door on the passenger side. A few squirts near the top and upper side will give enough electrical conductivity to energize the lock.
Oct 29, 2013 | 2007 Chevrolet Tahoe
Drivers side slider on 2001 Ford Windstar is jammed. How canI get it to open?
The door lock is not working. Operate the remote keypad, the driver's armrest door lock switch, and the overhead switch until you hear the latch work, then open the door. If this approach fails, 10A FUSE 11 in the central junction box may be open or the rear electronic module may have failed. Once you have the door open, apply WD-40 to the mechanical parts of the latch to prevent future problems.
May 07, 2017 | 2001 Ford Windstar
2006 buick lucerne back doors won't open
My friend just had this problem and he reached in and pulled the inside door handle back as far as it would go, and then let it go, allowing it to 'snap' back. For some reason this fixed it. We have no idea why. By doing this on one door, both rear door locks freed up and the rear locks are now working. Before, both rear locks were stuck and you could not open the doors from the inside nor the outside. Not sure why it works, but maybe it will work for you!
Jun 10, 2011 | 2006 Buick Lucerne
Drivers side door won't open from inside and its not the handle-already replaced that. also outside handle is floppy and sometimes the lock doesn't want to unlock with key
The latch assembly needs replacement as well as the springs on the outside handle. You can try to lube the latch with alot of WD-40 and see if it helps. If it doesn't then the latch will need replacement
Mar 31, 2010 | 1996 Ford Explorer
We live in a cold state (MN) and this year though it hasn't been incredibly cold our 2000 Kia Sephia constantly freezes shut. The power door lock on the driver side won't move from the inside or the...
part of the problem with being in such a cold place is even tho its so cold there is still moisture in the air. if you door wont close or open, you need to check the latch out and make sure its not just bent. as for not being able to unlock you door. the latching system is connected to the lock and handle. if the latch wont move don't use wd-40 that will make it worse. you need to pull open the door panel and get it greased with a grease gun. wd-40 will not keep the parts moving in that kind of cold. if latch wont reset
when you get it open, it wont close. just grease it up. oh it would help if you get water guard for your windows. protect you parts from freezing. take care.
Feb 22, 2010 | 2000 Kia Sephia
Motor Max 1964 1/2 ford Mustang Convertible Diecast Model Car 1:18 Scale Die Cast by  Cream White 1 of 3064 Logo
181 people viewed this question
Top Motor Max Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Motor Max Toy Expert? Answer questions, earn points and help others
