Question about Sport & Outdoor - Others
I have a crosman model 38C revolver when i go to put the co2 in the handle and screw the clamp down all the gas goes too
  • 677 Answers
Hi, use this as a guide
(anotherairgunblog.blogspot.com/2009/11/fixing-crosman-622-part-2.html).
Take care.
Posted on Jul 16, 2010
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
I had my Crosman 357 for about 15 years or so. I never used it at all until a couple weeks ago and it worked great for a few days and I liked it so much I bought more "clips", ammo and CO2 for it and then...
Well I recently bought a crosman like a month ago, I worked great, I also use CO2, then i started using it again, and all of a sudden all of the CO2 started seeping out of the barrel and CO2 area, cartridge after cartridge, so i said screw it and took it apart, and found the area that deals with the CO2 and tightened everything up. I couldn't put it back together, so i looked for the schematics and finally got it back together, then i tested it out and it works fine now. Good luck.
Oct 25, 2010 | Crosman Optics
I have a crOsman model 1077 that wont take a CO2
Probably not by you, but by the shop, maybe. It sounds like the needle was bent and lost it's seal. Crosman has repair stations, if they don't fix it, they will send you another one. I have sent them guns before and got brand new ones instead of the old piece of junk I sent them for repair. They also bought out Sheridan/ Benjamin line of Air rifles, And they repair all those too. I sent them an ancient rifle, an old Benjamin Franklin,17 cal. bare bones stock and barrel only, they sent me back a total refurbish, welded, painted, new .22 cal.barrel, all new guts, unbelievable. I think the total cost was $35 on that one. They wanted $15 for paint, I told them I didn't want it painted, they said, OK, Get a hold of them. Hope this helps.
Jul 03, 2010 | Crosman Optics
Info on repair crosman 150 air pistol
This is better known as a Crossman Air Pistol and it is powered by co2 cartridges that will not last too long once puntured/installed in the pistol, they tend to leak out within less then a day if not being used so try to use the cartridge once you have it in place.
Some fire BB's and some fire pellets.
Wear protective eye wear and clothing and always fire down range never point any pistol at anyone when handling it keep your fingers off the trigger and point up or down range.
Happy Target Practicing!!
Sep 29, 2009 | Computers & Internet
I have a crosman c11 that leaks gas
Ya your better spending the extra money on something with quality
Aug 12, 2009 | Crosman (4032)
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Sport & Outdoor - Others Logo
506 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
John Tinnemeyer
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
