Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch which outlet it's plugged into it seems to work for another couple minutes and stops again.
    President:
  • 2,702 Answers
Well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Posted on Jul 15, 2010
My Kenmore Elite Oasis will not power up and I can not even get a error code. Circuit breaker is good what do I do? I am stuck on this right now!
r u sure circuit breaker is good? did u check the washer terminal black or timer for voltage??
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Mar 24, 2015 | Kenmore Washing Machines
Microwave tripping breaker
The microwave may be too big for the circuit it's on. The breaker is tripping to protect the circuit. Try to determine how many appliances/lights/etc are running on this circuit. If there are alot of things, you may try turning some of them off when trying the microwave. If not, then you may have an electrical issue in the wiring or the breaker.
NEVER replace a breaker/fuse with anything larger than what's already in there (recommended by code or a manufacturer).
Feb 15, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
Kenmore Elite 45986 Front Load dryer wont get hot ?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Nov 16, 2010 | Kenmore Elite 45986 Front Load Washer
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
My dryer just stopped running?
It could be the door safety interlock switch. Remove the switch short the two wires and press start. If it works remove the short to stop the dryer and order a switch. If you have an Ohm Meter you can test the function of the switch without shorting the switch.
Jul 16, 2009 | Kenmore 63942 Dryer
House circuit breaker trips when machine is set to delicate wash
Motor controller or motor itself has a short.
OR something stuck in the pump impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 22422 Top Load Washer
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
191 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
