Question about Yamata Gravity Professional GSI-8800 Iron
Broken iron cord need an iron repair person?
The cord on my gravity feed iron has an intermittent short in it. Does it HAVE to be replaced by a gravity feed iron expert? Can any small apliance person do it?
  • 3,083 Answers
Depends on warranty stipulations, mainly, and finding someone who knows how to do it. Doesn't hurt to ask if the appliance guy can do the job.
Posted on Jul 15, 2010
Fix Rowena iron with retractable cord
I would contact a small appliance repair business near you, they can supply the needed cord and the repair for very little money I would think
Sep 23, 2016 | Irons
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Disassembly Process
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
My gravity feed iron won't turn on.
Your brand new iron probably is defective. Funny how no one wants to have anything to do with repair or replace. You may have to get another iron that that works.
Feb 01, 2014 | Irons
Replace cord
yes you can change it or you can also take some repair.
Jan 19, 2014 | Panasonic NIA56NR NI-A56NR Iron
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
Jul 13, 2011 | Oreck Cordless Speed JP8100CA Iron
I have a B&D 2030 steam iron which I really like, but recently it isn't always turning on when plugged in. I think there may be a short in the cord somewhere, possibly the plug?? It seems to work...
Likely the wire inside the cord is broken from lots of use. You can usually tell where by turning the iron on while plugged in and bending the cord. You will hear a spark when you bend the spot with the break. It isn't very difficult to replace the cord with a new one.
May 31, 2011 | Black & Decker D2030 Iron
The cord has a sort. how do I find a replacement
When you say short, it means to most people that you have intermittant connection in the cord, and one would say, replace it with the same or better type cord. If you are good at soldering, wire splicing and crimping, it should be fairly easy to separate the base using Security Torx Bits (i.e. tamper resistant screws are used), and a bit of judicious patience. Once appart, if they use crimped or solder connections you can cut, splice and crimp as needed. Your cord will be a bit shorter and you will have to reindex the strain relief service loop, but it should be painless. If you are not confident working with UL listed safe equipment (your loved ones will be using this appliance) you can get it serviced here:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Jun 06, 2010 | Rowenta Professional Luxe DM880 Iron
The cord gets hot
You have a short somewhere in the cord. As this is a risk for fire, the Iron should either be taken for repair or replaced.
Aug 03, 2009 | Black & Decker Irons
Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Jul 22, 2009 | Rowenta Irons
Broken electrical cord
if the wires aren't bare, wrap them in electrical tape. PLEASE RATE MY ANSWER.
Mar 07, 2009 | Euro-Pro Shark GI475 Iron
Yamata Gravity Professional GSI-8800 Iron Logo
140 people viewed this question
Top Yamata Irons Experts
Marvin
Marvin
Are you a Yamata Iron Expert? Answer questions, earn points and help others
