Question about Motorola Mobility H700 Wireless Headset
Dont know how to put device in discoverable mode
Got a new phone trying to add the blue tooth device It says to put it in discoverable mode. I cant find my manuel and cant figure out how to do this
    President:
  • 1,118 Answers
I might be wrong, but I think there are some H700 headsets which support smart find. If this is your case, you must ensure that all the bluetooth enabled devices, which have been previously paired with it, have their bluetooth radios turned off. Then, some 5 seconds after you open the headset's boom, the light should become steadily lit, thus indicating it is in pairing mode. Otherwise (i.e. if it doesn't support smart find), with its boom closed, press the call button for some 5 seconds, until the light is steadily lit. Then, open the boom. Either way, turn on the bluetooth radio of the device you now want to pair your headset with, and make it search for new devices. After a while, the H700 should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN or passkey) is requested, enter '0000' (four zeros).
Hope you are able to sort your problems out.
Regards, Carlos
Posted on Jul 15, 2010
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
I cant figure out how to put my blue tooth in discoverable mode
you can turn on from extra > blue tooth settings > change mode ( discoverable yes ) and then click ok. it will work now.
Dec 18, 2010 | Cell Phones
I am not able to connect my new phone with my Schneider car audio but my old phone works fine. It only detects my old phone not new one.
Make sure blue tooth is enabled on new phone plus the phone blue tooth device is set to discoverable mode Otherwise nothing will find it.
Aug 12, 2010 | Car Audio & Video
Cant pair phone with blue tooth
make sure your bluetooth is in Discoverable mode with BOTH devices , the try it again
Jan 02, 2010 | LG RUMOR Cellular Phone
No manual I can pair but dont have any other directions
you can send pictures, sound via bluetooth-no need pairing.both device must have turn on bt and be in discoverable mode.
May 27, 2009 | Cell Phones
6630bluetooth prolem
FIRST OF ALL RESTART YOUR MOBILE PHONE. THEN TURN ON YOUR BLUETOOTH CONNECTION ON YOUR PHONE. ALSO SET YOUR PHONE VISIBILITY ON FROM YOUR MOBILE BLUETOOTH MENU.
THEN TURN OFF YOUR BLUETOOTH DEVICE. NOW PRESS AND HOLD THE POWER BUTTON ON YOUR BLUETOOTH DEVICE. WHEN THE LIGHT BLINKS YOUR BLUETOOTH DEVICE IS DISCOVERABLE FOR YOUR PHONE.
NOW SEARCH FOR A BLUETOOTH DEVICE FROM YOUR MOBILE'S BLUETOOTH MENU. YOUR DEVICE WILL BE DISCOVERED BY YOUR MOBILE. NOW ADD THE BLUDTOOTH DEVICE TO YOUR MOBILE THE PASSCODE SHALL BE 0000 OR 1111.
NOW YOU CAN USE YOUR BLUETOOTH. IF STILL UNBALE TO EXCESS PLS. ASK US.
PLS. RATE MY SOLUTION.
NICE DAY
REGARDS
KETAN PATEL.
Feb 12, 2009 | Nokia 6300 Cellular Phone
Bluetooth
if you are trying to pair it with a car... put it into discoverable, then when the car is looking for the phone click add new device
Jan 08, 2008 | LG enV VX9900 Cellular Phone
Discoverable Mode
Here is the on-line manual: http://www.motorola.com/mdirect/demos/how2_h3/main.html -First off make sure the headset charges for at least two hours. Also make sure theindicator light turns on indicating charging is occurring. -After the charge is complete you will need to refer to your phones manual to pair the headset to the phone. The discover mode is a mode the phone goes into not the headset. I don't have an LG8600 nor can I find a manual on-line so I can't help you with that part. If you still need assistance let us know and please don't forget to rate the posting.
Jan 23, 2007 | Motorola Mobility H3 Bluetooth Headset,...
Motorola Mobility H700 Wireless Headset Logo
526 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
