Question about Intel Computers & Internet
I don't know how to put my tower together, or check parts
All the hardware has been removed and the wiring disconnected from the tower of my home computer.. I am not sure how to reconnect it, or how to check the parts to ensure i still have what I need.
  • 177 Answers
The minimum you will need is: Power supply, Motherboard, RAM, HDD, CDROM. The manual of the motherboard will tell you where to connect everything. If you don't have it, look online. They are nearly always available on the manufacturers website.
Posted on Jul 17, 2010
Tower turns on, but not the monitor or the keyboard
There seems to be a problem with the motherboard. You need to get your hardware checked.
Alternatively, there is a solution that worked every time for me.
Disconnect The A/C Cord or Charger from the laptop,
Remove the battery,
Hold the Power Button for 45 seconds.
Put everything back together and then try!
Tips : Use a cooling pad or a hard surface to keep your laptop on. Sometimes this problem occurs due to improper ventilation & overheat problems.
Good luck !
Feb 14, 2013 | Acer Computers & Internet
Wiring digram
They have several docs. Here are two pages that might help.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/techov.htm#wp1053345
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1043338
Jan 15, 2013 | Dell Dimension E521 PC Desktop
I took my arrow ET200 nail master apart to remove jammed nails. I need a diagram on how to put it back together
Susan Sylvia is exactly right. I just fixed my tool with her information. I would add to be very careful not to disturb the 2 small springs(associated with the trigger and safety mechanisms) and take note of how they are positioned. Also, the screws seem to strip unusually easily so be gentle when removing and replacing them.
Jan 24, 2012 | Arrow ET200 Electric Brad Nail Gun
I have a 1995 nissan maxima where is starter/celinoid lacated and are they together?
The starter and soliniod are together in this car and located in the front of the engine under the airbox. The starter is only held in with 2 bolts and the wiring. You may not need to remove the airbox completely but it may be easier I the long run if the mounting bolts have rusted over the years. Remember to disconnect the battery before starting this job. Also, make note of how the wires are connected before you remove them.
Disconnect battery
Remove top of airbox (cover)
Make notes on how the air hoses and wiring are hooked up.
Loosen clamps on hoses to airbox and disconnect any electrical connectors. Remove the attaching hardware for the airbox and remove.
Make notes on wiring to the starter/solinoid. Remove/ unplug wiring to starter.
Remove the retaining hardware. For the starter and remove.
I recommend bringing the starter and solinoid as an assembly to a parts store capable of completing the tests because they do it for free and assume responsibility for the test by doing the job. ; ) (autozone, pepboys do this test for free)
Determine faults and replace as necessary.
To install, reverse removal procedures.
Jan 17, 2012 | 1995 Nissan Maxima
TL Magna replace strut top bushes how to drop
try not to kill yourself.
You need a spring compressor for this job.
Three nuts on top , two at nuckle , disconnect any brake hoses or wires attached to strut if present ,
If brake hose goes through the bracket on the strut , and there is no options but disconnect brake line , I usually cut bracket carefully the way I can split bracket and take hose out without disconnecting the brake line.But make sure that it cut really nice so you can put it back together with locking spring.
After that , take strut assy. out and COMPRESS THE SPRING (spring compressor) ,after-take center nut on top of the strut out and you done. Memorize the way (mark it) spring was sitting , and sequence
for the parts and put it back together .
Installation - opposit of removal.
May 05, 2010 | 2003 Mitsubishi Lancer
Broken light switch chain
Open the fixture where the switch is and see if the chain is broke or just needs a connector to put the chain back together. If you can't do this,just take switch to a place that would sell them, hopefully
you have a hardware store,I hate home depot. Cut the 2 wires,
install new switch, connect wires, wrap with elec tape.
Apr 08, 2009 | Hampton Bay 24002 Ceiling Fan
Frigidaire Actuator model glhs68egpb1
that awaur is definalty apain in the rear to reconnect, i would first see that the wire is in correctly( should fold along normal lines to get proper orentation)check both end of connection, remove power first, so as not to blowe any circuitry,a small pieceof masking tape should hold the wire at either end to teh facade so as to minimalize the stress/flexing of ribbon wire. be sure to check the up[per wire harnesssa s well, perhaps you disconnected and never re attached
Jan 06, 2009 | Refrigerators
Mirus Desktop Computer
green-white for front panel Power indicator LED , Blue-white for RESET Switch , Orange-white for POWER BUTTON , Red-white for HDD LED . The berg pin header on the motherboard will have these legend printed just beside the connector or due to lack of space slightly away from it .
Apr 15, 2008 | Computers & Internet
Hard drive
Hello!
Removing the hard drive shouldn't be a problem. Make sure that your computer is plugged in but the power is turned off. Rest your arms on the metal of the case to ensure you are grounded and do not fry any parts with static electricity.
Remove the drive by unplugging the molex (the part hooked in to your drive that is wired to the power supply) and the IDE cable or SATA drive cable.
If you need to plug IN a drive, that would be different and potentially more complicated but you only ask how to disconnect it. If you do need additional assistance, please let me know. If I misunderstood your question, let me know as well and I'll try to offer additional solutions.
Jan 17, 2008 | Computers & Internet
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
