Question about Whirlpool Duet GHW9150P Front Load Washer
I turned the washer on without turning the water on how do i reset this machine
  • 11,896 Answers
Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tubUnplug the washer or disconnect power for two minutes, then plug the washer back in or reconnect power.Reselect the cycle, then press "Start."
Posted on Jul 15, 2010
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
Cold/hot water is not coming when I turn on the washing machine
Try unplugging the machine and turn the dial all the way around once back to where you would normally start your wash do not pull out the nob to start the cycle until you have plugged the machine back in, this will sometimes reset the main controller (the control nob you turn) if this does not work chances are you need a new controll switch or timer as some people call it, hope this helps.
Sep 08, 2012 | Kenmore Washing Machines
Our GE top loader washer has been known to overflow - hence I only ever do washing when I am home. I purchased a simple water sensor alarm that alerts (loudly!) when sensing any water on the floor - so far...
Sorry to hear about the flood and the resulting damage.
Their would see to be a problem with the control since as a general rule washers do not just randomly turn theirself on without action on your part to turn it on. Without a model number i just have to assume it has a touch pad that is bad that causes it to just turn itself on.
GENE
Sep 21, 2011 | GE Washing Machines
I have a wd62 washer/dryer. my machine will not fill with water but will wash and spin, can you please tell me what i could try. thank you.
In practice the washer should not wash without water in, if it does wash without water, then it could be a faulty or sticking water level switch.
The other possibility is the water inlet hose is frozen, turn the water off to the washer, remove the inlet hose, and lower it into a bowl or bucket, then turn water back on, and see if it comes through o/k.
If it does, then problem is in the washer.
Dec 19, 2010 | Hotpoint Washing Machines
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
How to reset the system
Hiya,
in most cases of a none responcive machine after intalation many people forget to turn the water tapes back on after conecting the machine this will stop it in its tracks so i would surgest double checking you have returned the water connectors to the on posistion, unpluging the machine for a few mins should reset the programme.
Hope this helps
Apr 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer does not work!
NF = No Flow (water).
1.Is the water turned on? 2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Program Selector Knob keeps turning
when the knob keeps turning, it is giving you a code by the blinking red light. count the blinks. i have a manual to explain what the codes mean and how to test the parts
Jan 07, 2008 | Splendide Comb-O-matic 6200 Non-Vented...
Whirlpool Duet GHW9150P Front Load Washer Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
