Question about Radio Communications
Cigaret lighter and radio have no power pulled and checked relay on p-*** side under hood dr side interior fuse good where else do i look
    Genius:
  • 1,274 Answers
Hello, My Name Is John, Let me see if I can help you. First most cigarette lighters require the ignition switch to be turned on to enable it too work. If that does not work, I will post answers here....hope this was helpful....
Posted on Jul 18, 2010
Where is the fuse for the windshield wipers on a 1999 Saturn SL?
It is located on the fuse panel on the Passenger side.
Look for the removable panel that is located below the radio/center bezel on the right side (passenger side). It's not part of the center shifter console, but just forward of it. Remove the panel marked "Fuses"! You will find the Wiper Fuse in this panel along with the fuses for the Radio, Accessory Power Plug/Lighter, Power Door Lock & Window Relays, Fuel Pump Relay, Cruise Control fuse, exc......
Hope this info helps!
Jul 25, 2014 | 1999 Saturn SL
Kia rio fuse on the back of th
Dose your cigaret and clock work if so get a multi meter and test at your radio harness if power there more than likely your radio bad if the cigaret lighter and clock don't work check your under dash fuses usually located drivers footwell left side above brake black box
May 17, 2013 | Car Audio & Video
Cigarette lighter wont work on my 1998 acura 3.2 tl. Dont see a fuse under the hood
The cigarette lighter works only with the ignition switch in the ACC or ON position. In the under-dash fuse/relay box, you will find the cigarette lighter relay and the 10A RADIO fuse 11. If the fuse is OK, check 15A INTERIOR LIGHT fuse 57 in the underhood fuse/relay box. If OK, check 50A IG SW fuse 36
Oct 09, 2012 | 1998 Acura TL
2004 Acura RL, I put a phone charger in the cig lighter and the lighter and the radio has stopped worker. I checked all fuses and they are fine.
Applicable fuses:
Under-hood fuse relay box: 7.5A BACK-UP RADIO fuse 56, 20A INTERIOR LIGHTS fuse 67
Under-dash fuse relay box: 10A ACC RADIO fuse 4, 20A BOSE SYSTEM fuse 9
If all of these are fine, everything should be working
Sep 27, 2012 | Cars & Trucks
I have no cigar lighter hahe changed cigar lighter
Take wires out of cigaret lighter , then replace fuse , if fuse stays ok without cigaret lighter connected then something shortning lighter inside.
May 07, 2010 | 1993 Honda Accord
I was conecting a transverter to my secondary cigaret lighter and i touched the negative and positive together and now it wont work where is the fuse for it on my 04 toyota corolla
You won't necessarily find a fuse for this but check under the dash on the drivers side for a fuse box. Also under the hood but if none of fuses are blown you have lost what is called a fuseable link in the wiring harness and you wont be able to fix that. The way to easily get your lighter socket working is to buy from radio shack a fuse with wire attached and get some extra wire around 14 to 16 guage and a 10 amp fuse and run a new power line from the fuse box under the dash to the lighter socket. Use the same ground that is there. Radio shack also has taps for the fuse box. I just did this on a Ford Escort and it only took 20 min.If this helps please reply and let me know if you need more details good luck
Apr 26, 2010 | 2003 Toyota Corolla
2002 dodge grand caravan--radio cigarette lighter power out
there is another fuse box under the dash on the driver side. if you have your manual, look up the fuse positions in it and find the proper fuse. if i read your ad properly you have no power to the radio or cigarette lighter. this circuit is on one fuse in the fuse box under the drivers side dash
Dec 24, 2008 | 2002 Dodge Grand Caravan
Fuses
the fuse for the cigarette lighter is located in the fuse box under the hood. It is a 20 Amp (yellow fuse) in position #32. You can check the lid of the fuse box under the hood for a diagram to show the positions.
Aug 30, 2008 | 2001 Pontiac Aztek
FPontiac G6 cigaret lighter fuse location
i have a pontiac g6 and i need to locate the cigarett lighter fuse box so i can replace the fuse. 2006 model
Jun 29, 2008 | 2006 Pontiac G6
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
