Question about MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX / Phenom X4 / Phenom X2 / Athlon X2 /AM2 Athlon 64 X2 / Ath... Motherboard
I'm getting an overclocking error from my K9A2 CF version 2 motherboard. How do I fix it?
  • Ann Schafer Jul 15, 2010
    Thank you very much for quick response. My computer is FIXED!!! This is one service I'm going to keep.
  • MSI Master
  • 4,806 Answers
Have you tried re-setting your BIOS? If not, turn your computer off at the mains and disconnect the power cable. Take the battery out of your motherboard for 10 minutes. Then pop it back in and see if it works. It may ask you to setup your bios again, or just load the defaults settings and see if the error message is cleared.
To get into the BIOS restart the computer and hit either the Del or Esc key.
Please post back if you need anymore help.
Good luck.
Posted on Jul 15, 2010
Msi n1996 motherboard driver
This is your lucky day. I have that very board in my hands and was able to find the downloads on the MSI website. Cut and paste this link to get to the driver downloads. Pick and choose what you need. Don't let the MS-7388 bother you. You can click on the photo and see both MS-7388 and N1996 on the board.
http://msi.com/product/mb/K9A2-CF.html#/?div=Driver&os=All
Dec 24, 2011 | Computers & Internet
MSI K9A2 no sound
check the cable hav any loose or check the drivers
Jan 14, 2010 | MSI K9A2 Platinum Motherboard - AMD790FX,...
Problem with MSi K9A2CF mother board
More info on what happens from powering up your system and some of the devices listed you are using
Jul 22, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
How do i get rid of a blaster bug located in the bios , MSI k9a2 cf board without going on the internet with this computer,phenom 3 core proc, tried a antivirse software , nothing found, formated HD
Try using a good Antivirus software like McAfee, PCCilline, Norton Antivirus, NOD32 etc. First download the Antivirus and install then update it. In most cases such problems are solved. (ehteshamhusain@gmail.com)
Apr 21, 2009 | Computers & Internet
Problem in overclocking my Processor.
1: You problem is your power supply, PSU. When you try to give more power to your CPU by overclocking it, it doesn't have enough wattage, or power, to get the CD drive, or your sound card to work. This is why the CD drive works again when the CPU isn't overclocked. So, in this case, to overclock your CPU, you would have to get more power to your system by getting a more powerful PSU, or one with more wattage. How much you can overclock your processor depends on a variety of different things. Your RAM, PSU, HDD, CD drive, etc. I would not go past about 3.4ghz with your processor, however, a "max overclock" is hard to determine.
2: The maximum temp for your processor is 70C, 158F. I would try to keep your temperatures under 60C to ensure your processor doesn't "die early" on you. The multiplier cannot be changed, only the FSB can be changed. You should be able to create a "profile" in bios and set it to your default so that it loads up automatically when you boot up. Make sure you find a stable configuration before you make a default profile.
Mar 30, 2009 | Intel Computers & Internet
Bios Beeps during reboot
According to the information at:
http://www.pchell.com/hardware/beepcodes.shtml
AMI beep codes of 1 long and 3 short are, in fact, correctly identified as memory errors. One thing to note is if this memory is Dual Channel, you can only install the memory in groups of two. You must first fill DIMM slot 1 and 3 before filling DIMM slots 2 and 4.
The below website has much more information about your particular motherboard and there's a note about some JEDEC setting for memory that you might want to watch out for or disable to see if it improves stability.
http://www.msicomputer.com/product/p_spec.asp?model=K9A2_CF-F_V2&class=mb
As for Windows XP 32-bit not recognizing more than 3.5 (at most) memory, this is unavoidable. To see all 8 GB, you would need a 64-bit version of Windows. This is something that cannot be altered by BIOS or memory choices, unfortunately. Feel lucky in the fact that you have XP Pro as XP Home will only recognize up to 2.5GB. You'll never utilize all 8GB unless you upgrade your OS, so keep that in mind!
Mar 04, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
New Motherboard Problem
I believe you have a driver conflict
Check your BIOS is set for CPU etc.
And Uninstall all drivers And see if computer start with only the windows drivers present.
As if you have just installed windows and no M/board drivers.
And reinstall M/board drivers one at a time Should fix your problem
Nov 03, 2008 | Intel Motherboard
Detecting hard drives
try bios settings it may be set for a particular hard drive not yours and not on auto detect set for auto detect
Aug 02, 2008 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
Anyone experience problems with an overclock E-125?
There are some overclocking programs available like through www.jimmysoftware.com or even hardware fixes. The one by jimmysoftware is for the iPAQ only. iPAQ Overclocking software I would strongely avoid doing the hardware fix. The overclocking applies only to the processor itself and does not take into account the I/O from the the processor to the various other hadrware components. Some games, video, and apps may perform better but anything hardware related like PC card or CF cards that have a function like modem, networking etc. . . can run into timing related issues and not function. At least the software version can be easily removed. Good luck
Sep 04, 2005 | Casio Cassiopeia E-125 Pocket PC
MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX / Phenom X4 / Phenom X2 / Athlon X2 /AM2 Athlon 64 X2 / Ath... Motherboard Logo
57 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
