Question about McCulloch Garden
My chain saw has no spark Model 10-10S - McCulloch Garden
    President:
  • 2,220 Answers
Is this your saw?
Chain Saw Collectors Corner
Pro Mac 10-10S
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/8f167f396637c29d88256c2e0073560e?OpenDocument
If yes the model number is 600111
The coil is pn 223708-01
The wire assembly is pn 223884
I found both parts at M&D Mower for <$40. Also available on eBay coil only >$50
Test the entire ignition system (If no spark, try it again with a known good plug – cheap insurance). You have a separate high tension wire (continuity test the wire); ensure the connection at the coil and plug, are good.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap (if needed)
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 19, 2010
  • dontbother10
    dontbother10 Jul 19, 2010
    Please check the high tension and kill wire for shorts to ground as well. Lou
    Sergeant:
  • 200 Answers
Try a new coil.
3 Suggested Answers
  • 10865 Answers
SOURCE: spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Posted on Feb 07, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How much to tighten spark plug on stihl chain saw model 028?
General rule is to tighten it by hand, then turn it with a ratchet another 1/8 to 1/4 turn.
May 06, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Chain saw has no spark
If it has no spark there are only a few that will cause this, firstly dissconnect the wire from the ignition switch, try again for a spark, if no spark, remove the starter cover, now remove the cut out wire from the ignition unit terminal, try again for spark, if no spark, the ignition unit is bad and will require replacment.
Feb 14, 2011 | Craftsman sears 18" Chain Saw Chain (...
NEED THE SPARK PLUG CHAMPION FOR POULAN MODEL 2400 CHAIN SAW
Huh? CJ8Y and RCJ8Y are SAME heat-range. Latter has internal resistor for RF noise suppression.
Nov 15, 2009 | Poulan Pro Chain Saw 46cc 20"
Apr 27, 2009 | Garden
WHAT IS THE SPARK PLUG GAP!
.020 according to the site I just looked at.
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Spark plug gap
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Change Spark Plug on Eager ****** Chain Saw
yea you have to take it apart sorry
Oct 06, 2008 | Garden
Garden Logo
362 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
