Question about Dryers
Hoover 5050ED doesn't seem capable of taking a full washing load. It's almost like the motor has/is losing power. When you start the dryer it's like the motor can't start rotating, until you only have about 4-5 items left in there.
  • maq80209 Dec 14, 2008
    same problem what the solution???????????????????
    Sergeant:
  • 351 Answers
Change the motor capacitor
Posted on Apr 22, 2008
Hoover Nextra 7148 not drying
id check for fluff inside the machine casing.............blocking the air flow...........
cheers
Aug 30, 2017 | Hoover Washing Machines
Our old Hoover washer dryer had been working perfectly and then started tripping out - it would seemingly lose power mid cycle. We tried it in different plug sockets and using an extension lead with a...
ok I assume from what you are say that the circuit breaker in the consumer unit (fuse box) trips it could be that the circuit breaker is beginning to fail (they can go weak after prolonged use) and will tend to be a problem on high load appliances the water heater will take around 12.4 amps as will the dryer heater get the circuit breaker changed
Oct 24, 2013 | Hoover Washing Machines
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
Our Hoover (3535d) dryer tumbler does not want to spin although you can hear the motor starting. The load does not appear to matter. There is no sign of belt slipping. Can the problem be due to the start...
If you hear the motor starting then it normally wouldn't be the start capacitor. It is when it doesn't start that you suspect the capacitor.
If your motor is turning and belt is NOT slipping then your drum should be turning! Those things do tell you that your electronic (control board and timer) are good, but you are wrong about either the motor or the belt!
Jul 03, 2011 | Hoover Dryers
5050ed buzzes onstart up ,needs little manual turnover to start
it can be the idler pulley that tightens the drum belt,the drum belt itself has gotten old and glazed from age,or the motor that turns the drum the bearings can be getting dried out from age and heat and getting tight requiring help to start,also the motor start switch on this motor can be getting bad contacts inside this switch,all these issues require you to dismantle the unit to some extent to check them
Jan 29, 2011 | Hoover Dryers
Hi I have a Hovver 5050ED Dryer, I have replaced the belt but the problem is still happening. When you load the dryer push the door button in & press start the drum doesn't turn the motor hums but if...
It sounds like your motor is faulty and cannot handle the load resistance.
You need to have the motor changed or have a Whirlpool engineer come and take a look
Jan 27, 2011 | Whirlpool LER4634J Electric Dryer
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
Hoover 5050ed clothes dryer/tumble dryer
If the dryer hasn't been mounted before, you'll need to punch the blank slots through. At the bottom of the dryer (because you wall mount it up-side-down, so these slots will then be at the top), you'll see a vertical hole in one layer of the metal on the back to each side. Knock these through to reveal the holes where the bracket can go in. You'll also want to replace the control panel decal with the wall mount one that has all the controls up the correct way when wall mounted.
Jun 04, 2008 | Dryers
Can't get the dryer to work! - Hoover 5050ED Heavy Duty 5.0 Kg Auto Dry Plus
ditto and exactly 2 years later! Someone please help!
Mar 03, 2008 | Hoover Dryers
Dryers Logo
621 people viewed this question
Top Dryers Experts
