Question about Canon AV1 35mm SLR CAMERA SPARES OR REPAIR 35mm Film Camera
My canon av1 will not wind on the arm is stiff
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jul 18, 2016
Tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 | Watches
I have a 35 mm canon ae-1 camera. I havent used it in a while and I was just trying to load some film but I cannot get the wind lever to work, and therefore also cannot use the shutter button. I am not...
Canon AE-1 will not work without a battery,so if your battery is low then most likely that is your problem.Battery compartment is located on the front of the camera.Replace the battery with a brand new one,used batteries even though they will read the right voltage(6 volts)will not have enough amperage to allow proper cycling of all moving parts.Buy a good quality battery like eveready,duracell,etc.hope this helps.
Feb 05, 2011 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Film release button on bottom of body is stuck in. Wont pop back out.
If you can not wind and release the shutter, the film release button will not come up.
If you can not trip the shutter, by replacing the mirror release magnet at the bottom will usually fix the problem.
May 22, 2010 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
My film in Canon ae 1 came out blank :S
I would say either the film didn't wind properly as it was going along,or the shutter isn't working properly.Did it make the whirring noise like it was winding after you took a picture?If you can,try taking a picture with the door open,no film,and see if the shutter moves.If it does open,it's probably the winder which pulls the film after a picture is taken.Good luck!
May 01, 2010 | Canon Photography
My men's presidential date just is very difficult to wind. I try to wear it often, but it quits. The winding mechanism is so stiff that I can only partially wind it. It does move easily in the oposite...
If it has only recently gone stiff then it sound like a trip to the dealer for repair.
It may sound daft but all the Rolex I have examined are self winders. Is yours? (you can often hear the self winding mechanism by placing the watch close to your ear and rocking it gently).
Could it be that you need to pull out the crown to wind it?
Feb 03, 2010 | Rolex Mens Super President, 18kt YG
Jammed canon at1 slr
Believe it or not, i just put a new battery in it and BINGO, back to life again....cheers G.
Jul 22, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
I have a canon AVI analog camera.Few years back
for this modal there is a lock on botam of ground glass ask the shop keepar to cheek that ,or cleen the dust at megnt.
Apr 09, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon av1 film advance lever will not extend
The AV1 is an electronic camera that has to have a good battery for the shutter to trip. You can find the 6V battery at most drug stores or Walmart
Nov 18, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Minolta X300 camera
Hello
First thing to check with this is are we are talking about the correct part of the camera, the rewind lever on this model is on the left hand side (as you look through the camera), make sure you have raised the rewind crank arm (small plastic arm) out of the central knob, then looking on the bottom of the camera you should find a recess with a chrome button in it, push this button in, it releases the wind on mechanism, you should now be able to rewind the film using the crank, make sure you follow the direction of the arrow on the arm otherwise you will wind the film into the canister backwards, this will make it very stiff to wind and maybe scratch the film, plus you processor will not like you for this either.
Aug 16, 2008 | Photography
Canon AV1 35mm SLR CAMERA SPARES OR REPAIR 35mm Film Camera Logo
183 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
