Question about Dell Office Equipment & Supplies
Paper jam at the bottom of my Dell V305w printer
Paper gets jammed at the bottom of my Dell V305w printer. It goes in about an eighth of a way in and then jams. No display on the screen except a ''!''. What could be the problem?
    Guru:
  • 366 Answers
Try to switch of and take out the data cable form the pc for a five minute
If it is not working reinstall the printer driver
OR
maybe following this http://www.fixya.com/support/r544787-getbestsupportprinterfrom_fixya might be of some assistance?
Posted on Jul 17, 2010
How to remove jam from a dell v305w printer
chk the paper censers of u r printer it's springs are out so it show paper jam
Feb 02, 2013 | Office Equipment & Supplies
I keep getting a Clear Carrier jam on my Dell V305w printer. I've checked the cartridges, turned off/on, unplugged, nothing's jammed and keep getting the same error.
Remove obstructions from the carrier path or close the cartridge carrier lids, and then press the Select button.You can try resetting the printer by unplugging it from the wall. Now remove the power brick for 60 seconds. This will reset any error messages the printer is getting.
There is almost always something in the paper path. (makeup brushes, push pins, paper clips, insect parts, jigsaw puzzle pieces, coins, toys etc. If all else fails, turn it upside down and shake.
or try to run a piece of thin 3X12 flexible plastic up and down along the paper path.
(It has to be stiff enough so it doesn't kink up and strong enough to shove out any blockage).In the absence of plastic, you can use some stiff cardboard or cut a piece of file folder to fit.
Apr 22, 2011 | Dell V305w All-In-One R840635AU InkJet...
Carrier Jam? What? I can't see anything wrong, I've cleaned it all, what do I do?
See if there is a door on the back of the printer. I have found paper jammed back there when I couldn't see it anywhere else.
Jan 27, 2011 | Dell V305w All-In-One R840635AU InkJet...
Paper jam
Hello there Ok try this
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 07, 2010 | Dell V305w All-In-One R840635AU InkJet...
Dell v305w printer not printing - saying paper jam but no paper in it
Hello there
Feb 20, 2010 | Office Equipment & Supplies
My printer says clear carrier jam
Hello there worth a try.
Feb 18, 2010 | Dell V305w All-In-One R840635AU InkJet...
My dell V305 keeps jamming and doesn't print
Hello there
Feb 17, 2010 | Dell V305w All-In-One R840635AU InkJet...
The clear paper jam remains on. no paper jam apparent
Hello there
Sep 24, 2009 | Dell V305w All-In-One R840635AU InkJet...
Says it has a paper jam but there is no paper in it!!!!
Often there is a small piece of torn paper in the vicinity of the paper sensing switch lever.
OR the switch lever has been damaged by forcibly removing a paper jam.
You should open the printer and inspect the paper path for these problems.
Sep 01, 2009 | Dell V305w All-In-One R840635AU InkJet...
Paper Jam , can't see the paper!
I disconnected the printer, turned it on its side with the exit slot upward. I was able to see the paper jam on its upper side. I took a paper clip, streightened it out with a hook on its end. I was able to pull the paper out with a longnose plier.
I printed the material that I wanted, but thre print was smaller than shown on the computer, too small to read. How can I make the printer to print larger?
Jun 04, 2009 | Dell V305w All-In-One R840635AU InkJet...
185 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
