Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
My intex pool filter is constantly leaking and we are losing a lot of water. The water comes out of the top and leaks out. T
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Can I fix my input valve, on my sand filter, while water is in the pool?
IF YOUR ASKING IF YOU CAN REPLACE THE MULTIPORT VALVE ON TOP OF SAND FILTER HOUSING WITH WATER STILL IN POOL , SURE ITS POSSIBLE . 1ST UNPLUG PUMP POWER !!!! SECOND USING A COUPLE OF TRASH BAGS ADD ENOUGH AIR INSIDE OF THEM TO FIT JUST TIGHT ENOUGH DOWN INTO SKIMMER ON SIDE (ME I USE A OLD POOL TOY) WEIGHT OF WATER WILL HOLD THEM IN THERE , NOW YOU CAN DISSCONNECT YOUR HOSES , A SLIGHT TRICKLE MAY COME OUT (EASY TO REPLACE LOST WATER VOLUME) REPLACE THE VALVE , WAIT FOR GLUE TO COMPLETLY DRY (IF USED) THEN RECONNECT HOSES , REMOVE TRASH BAGS FROM SKIMMER(LET AIR OUT) , RECONNECT PUMP AND TEST FOR LEAKS
Jun 05, 2015 | INTEX Sand Filter Pump
Goodday i have a intex pool notice water missing over a course of a week think it is a very small hole as big as a pin how can i find the hole please help
If the hole is in the bottom of the pool it will be extremely difficult to find. I assume you have looked around all the sides for wet spots already. How much water are you losing? Are you sure it is the pool leaking and not the pump or filter? Look everywhere!
Nov 05, 2013 | Intex Pool & Spa
Sand filter losing prime
You will see NO leak if the pump is on.
But once the pump is off, then you may see a leak.
Jul 23, 2012 | Hayward Pool & Spa
What is the screw or nob in the middle of the intex 530 gallon pump lid for.
That is an air release valve screw. After you fill you rpool with water - open this screw until water comes out then tighten until sealed firmly. Turn pump on.
This allows the air to be released from the pump chamber "priming" the water flow.
Aug 05, 2010 | Intex Easy Set 530 Gallon Swimming Pool...
Im filliing my intex pool and found water trickleing from underneath, how can i find the leak. or should i continue to fill to better locate the leak?
Now let's find that leak! Fill the pool to its normal level and mark it. A piece of duct tape is ideal for this. Next with your filter system running the whole time, wait 12 to 24 hours and measure the loss of water. Then refill the pool back to the same level and with the filter system off, wait the same amount of time (also over the same part of the day, ie. 8 AM to 8 AM or 7 PM to 7 AM) and measure the water loss.
If you are losing more water with the filter system running, the leak is on the pressure side of your plumbing somewhere PAST the impeller of the pump. If you are losing less water with the filter system not running, the leak is on the vacuum side of your plumbing somewhere BEFORE the impeller of the pump. Please note that in this case, most of the time the pool only loses water when the system is off and not when it's on. If the water loss is the same, then your leak is in the structure of the pool and not in the plumbing.
Let's deal with a leak in the plumbing first. We will assume that there is not an obvious leak (one that you can see) on the filter system. Did you check where your backwash line comes out? There are two ways to find this leak. First, you can pressure test the lines, then dig, following the leaking line till you find it. You can also call in your local leak detection service. We would highly recommend the latter, unless you like to dig. Professionals will use "geophones" to listen for the leak and only dig where necessary!
Now lets look at a leak in the structure of a concrete pool. You will need some food coloring for this, and you will want to turn off the pump at least an hour before you do this. In a concrete pool, any cracks in the shell are usually obvious. By squeezing out the food coloring near the crack, you will see the crack pull the food coloring in. That will show you where the pool is leaking. Yes, you may have to get in the pool to do this, but isn't that why you got the pool in the first place? If there are no visible cracks, you will want to squeeze out the food coloring around any of the items that pierce the shell of the pool (main drain, returns, lights, etc.). Be sure to check the "mouth" of the skimmer where the plastic of the skimmer meets the concrete. This area is very susceptible to movement and often separates causing a leak.
Once the leak is found, it is easy to fix using a patching material. Most of them will work under water. After patching, check again with your food coloring to make sure you plugged the leak. Please note that if you patch near a fitting, you will want to leave the pump off while it cures, so the flow of water doesn't wash the patch away.
What if you have a vinyl pool with a leak? A leak can be a little harder to find and fix in a vinyl pool, but it's not impossible. We would recommend that you first check around all the items that pierce the liner (main drain, returns, lights, etc.). If you find that the liner has pulled away or is leaking behind a fitting, we would STRONGLY recommend that you call in your local pool professional at this point. If you mess this repair up you could easily be looking at a new liner!
If you do not detect a leak around the fittings, you will need to search the liner itself. A lot of vinyl liners have a pattern on the walls or bottom which can make it difficult to see a hole. Sometimes by running your hand over the floor and walls you may feel a tear or puncture that's not easily visible. If you have a friend who is a diver, he or she can do the job a lot easier with a tank than you can by holding your breath. Note: only certified divers should be using diving gear, even in a pool. Sometimes there is a depression on the floor which might indicate erosion caused by the flow of water. After finding the leak it is an easy matter to patch, using a vinyl patch kit and following the directions.
i hope this helps...let me know, thanks and good luck
Jun 27, 2010 | Intex Easy Set Pool 15x36
Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
May 20, 2010 | Intex Easy Set Pool 15x36
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
I had boughten a intex pool from a garage sale and the pool is fine but the filter is leaking water everywhere and all the water that is in the pool keeps coming out.
if it has hose clamps tighten them if the area that is leaking has o rings (they can become brittle and leak water) you can purchase them at local harware store
If it is a cracked housing they can be purchased at intex.com
call them up and order your parts
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Water filter leak
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Jun 26, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
210 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
