Question about Samsung HLP4663W 46" Rear Projection HDTV
Color wheel replacement
Is there a starting position when installing a new color wheel?
Picture is good but color is wrong mainly blue and can't adjust color.
  • steven d Apr 23, 2008
    Finally replaced new color wheel with original and the colors and picture is good but it is very noisy, squealing noise. Reordered new color wheel, at this time I have to believe the new part was bad. I also tried adjusting the CCA'S but that didn't help at all.
  • jstkidnu May 21, 2008
    just replaced the color wheel and the color is wrong mostly blue and also the picture seems alittle blured is anyone else having this problem? does anyone know how to fix this? i love the tv....help. thanks
Solution found!
This TV set is a 2004 and there is no yellow sticker on sheilding to indicate jumper plug position. I removed sheild and on pcb found test points had been soldered together, no pins on this pcb. Removed solder bridge and tried picture again and now it is working as normal, good color, no noises from color wheel, and good picture. This set was miss leading because access to pcb thru sheilding was blocked.
Hope this may help others out there.
Posted on May 12, 2008
I have the same problem. Iet me know if you get a solution.
Brandon
brand43076@charter.net
Posted on Apr 22, 2008
  • Brandonsox34 May 12, 2008
    From what I have read you need to disconnect a jumper cable that is next to the color wheel on new color wheels (not the case with original color wheel). Do a google search and you should find some more info. good luck and keep me posted.
I ordered and replace color wheel optima pro250x dlp projector and now I have a green screen instead of blue screen and colors are off? Could this be wrong color wheel or do I have to reset something?
i'm expert on optoma projector, i think i can help you.
please tell me whether the segments of new wheel from ebay are same as your old one?
if their segments are same as your old one. the wheel is correct. just need to make a small adjustment, it will be ok.
you can contact me by wanmingjun@gmail.com, send me a picture of your old wheel and that wheel you ordered from ebay. i will tell you how to do next.
Aug 18, 2017 | Televison & Video
Samsung HLR5078 50" tv - replaced a shattered color wheel but the colors are way off with the new one - yellow in place of both red and greens.
I'm not sure you received the correct color wheel. Do you have anything left of the shattered color wheel to compare it to the new one? Seems if you got the correct wheel then the colors should of been the same. Color wheels spin at the same rate of 60Hz. The only reason why you would get the wrong color is that the color on the wheel is in the wrong placed at the right time. I would see if you can get a wheel the same # as your original one.
Nov 11, 2014 | Samsung Bp96-01103a Dlp Tv Color Wheel L6...
Optoma gt700 is all green after replacing color wheel
we mainly retail or distribute color wheel, light tunnel ect sparet parts for projector or TV, so we have experience on that problem you faced.
perhaps you ordered a compatible color wheel,but it is not big trouble. compared with your old wheel, you will find a black tape, just make it as the same position as your old wheel, it will be ok.
Jun 25, 2014 | Optoma Office Equipment & Supplies
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
My Samsung HLP-4667W DLP TV has no picture when I turn it on.
The color wheel can be ruled out by looking at it---it faces the lamp and can be seen---look to see if any segments of the wheel are missing or if the wheel is totally shattered.
Other than the wheel I am concerned by "blue splotches etc" as it might be a DMD gone bad. Look at the attached photo and the color wheel first.
May 03, 2012 | Samsung Televison & Video
Epson 76C projector that the picture has no red color to it. I have tried the adjustments as described in the manual but no success. The blue and green is great but no red? Thank you.
Youve probably got something gone wrong with your dlp chip with the million mirrors on it, see when the mirror tilts away from the light you get a black shade- tilted toward light lighter shade now throw the color wheel in which gives you color youve got green and blue so the color wheel is fine. Now how to replace chip? Dont. Look for a digital board or video board replace that and that should take care of ya. Good luck hope this helped ya-
Aug 22, 2009 | Epson PowerLite 76c Multimedia Projector
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Installed new color wheel not working correctly
Hi danny,
I also replaced the color wheel in my EP739 after the old one disintegrated suddenly. Colours were then all over the place. Actually, it looked like each colour channel was displaying all the colours of the rainbow!
Here is the procedure I used to solve the problem - maybe not as elegant as Marrie's solution, but it will not cause any damage, will most likely solve the problem, and you will be able to get everything back to the way it was if it doesn't work:
  1. Have the projector running and displaying a stationary picture. The right sort of picture to use is one that has a full range of brightness values from near-black to peak white. I used my lap-top as the source. Also, this way you can compare the projector's picture with the picture on the lap-top.
  2. Press the power button once. "Power off the lamp" dialogue box appears. Hold down the left arrow button until the service menu appears (takes about 8 seconds).
  3. Using the up/down arrow buttons, scroll down to "Color Setting" and press "enter".
  4. Scroll up to "Color Wheel Index". Make a note of the existing setting for later reference. You can change the Index setting over a range of 100 to 550 by holding down the left/right arrow buttons. As the setting changes, the colour rendition will slowly change, and at some point the colours will come right. Note that the changes are quite slow. Find the lower and higher settings where colour aberrations just start to appear, and set the Index mid-way between.
  5. If this doesn't fix the problem, return the Index setting to original. My original setting was 354 and the new setting was 461.
I do not advise touching any other settings in the service menu unless you have access to a service manual and know what you are doing.
Father Dave
Mar 08, 2008 | Optoma EzPro 739 Multimedia Projector
Componet 1 and WII
First of all, make sure that you have the colors of the component cable matched correctly. You can switch the Pr and Pb cable and still get a picture although in the wrong color.
Secondly, go to the TV menu... the menu should still be in color. If it is in B/W then you might have a hardware issue. Try adjusting the custom color setting so that you get a blue picture or red picture. There is an option for adjusting the color called "blue mute" it should give you a perfectly blue picture. If you still don't get any color than it is a hardware issue. It could be the Main Board or the Control Board.
It was the Main Board in my case.
Oct 07, 2007 | Akai PDP4206EA Television
Samsung HLP4663W 46" Rear Projection HDTV Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
