Question about JVC Audio Players & Recorders
JVC HX-D7 Compact Component System turning itself off
system turns itself off
I have tired all of them so now what can i do
Posted on Aug 26, 2012
5 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: i just got a jvc
This seems that the unit switches off due to a protect cut off. It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Posted on Jul 01, 2011
SOURCE: PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Posted on Nov 23, 2008
toolkits
  • 1099 Answers
SOURCE: HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
Posted on May 19, 2010
I had the same problem with a jvc stereo set, it turned out the two cables of a speaker were touching each other.
Posted on Nov 30, 2007
"PROTECT" message in display.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Hello
May 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
I Have a JVC HX-07 that turns off itself after few seconds showing PROTECT message on display?
the unit may be damp inside.there is dew protection on most new units.It sometimes happens when units are used in the basement.unplug it and plug it back in again and see what happens
Jan 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Hello, I posted some time with you and I would like to buy from this compact component system CA-HXD7, but without speaker
This is a website that offers two levels of service help; it does not sell anything directly but only has links to those who do sell products.
Jan 04, 2010 | JVC HX-D7 Shelf System
My jvc hx-d7 radio is turned on in 2 seconds it shuts down to protect mode how do i take protect off ?
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
Nov 07, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
I have JVCD HX-D7 system. The'Protect'message appears when i turn it on. The'protect' message appears and the system turns off please help
I had the same problem, it could be that there are a number of different problems that cause this error code. I noticed my unit was extremely hot even when it was turned off. Try unplugging it for half a day and see if it works then, maybe only for a short while. If it's just overheating get a larger system ($10) fan (may need to drill some new holes to mount it) and flip it so it blows into the heatsink area for the amps. Drill a series of holes in the upper casing for proper air flow. you may see the amps are scorched as well they need to be replaced (easy) for about $40 for the pair.
Apr 12, 2009 | JVC HX-D7 DVD Compact Stereo Audio / Video...
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
236 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
