Question about Canon PowerShot S2 IS Digital Camera
When i turn on my camera the lense extends but you can not see thru neither the lense or the remote screen. please help
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jul 15, 2010
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
Lense won't extend when camera is turned on
lens has been damaged and it's most likely not worth repairing. lens can look fine but internal damage will require more money than it's worth. recommend replace
Sep 25, 2009 | Cameras
Lense won't extend. Has error screen that says "lense error, restart camera"
sounds drastic but turn on cam and grab hold of lens to try to fully extend it manually. if you hear a crunching noise that means the gears are stripped. not worth repairing
Jul 09, 2009 | Canon PowerShot SD600 Digital Camera
My Sony Cybershot w120 camera and now the lense won't pop out
Hi, there is no need to buy a new camera. The lens is avaible as a spare part. If you get a help from an authorized service they will solve your problem
Apr 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Help with cybershot dsc-w30
I had the same problem. This happened because the lenses is jammed and these always happened when u droop the camera or press power button while the camera in it’s carry case or even on ur pocket which led to an obstruction of the lenses to extend probably. In my case my son put his hand on the lens and stopped it from extending.
The solution is try to tape the camera gently with the palm of ur hand, may be some dust is the cause, If it did not work take it to the service, I highly recommend that you should go to the agent, and u should know that it’s only repair of the lenses u don’t need to replace the lenses. I went to some one to fix the problem and he said that “it’s need a new lenses but when I emailed the agent of sony they called me immediately next day and asked me to go to there service and they make it for me for free because it was in the warranty period.
I hope this help, and I’m sorry for my bad English.
Please have a nice time
Sep 01, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cyber shot dsc w55 7.2 mega pixels
turn on when lense extends take hold of the end of the lense and gently twist and pull the lense you may hear it click do not force the lense then turn on and off again this should solve the problem.
Aug 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Lumix TZ3 lens does not open
It is not clear if you are saying whole camera turns off or just screen turns off.
Notice before the camera went bad the lense does not extend in play mode, while it does in record mode. Many cameras have software that automatically turns camera off if lens cannot/fails to extend for some reason. Try to help it extend in record mode before camera turns off.
Feb 23, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
349 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
