Question about Toshiba 57H82 57" Rear Projection Television
No picture, no sound the tv was working normaly then ther was a muffled thump from it and it went off.
  • 10,594 Answers
Is power indicator on tv front lit/ blinks then tv got problem in deflection section and most probably in horizontal deflection section.
And if power indicator on tv does not lit at all then problem would be in power supply section that got damaged for some reason.
I'm not sure about your electronics knowledge and skills so local tv repair shop will help you get tv fixed.
Hope these info will help you.
Thanks.
Posted on Jul 17, 2010
  • 12 more comments
  • rawkdw2000 Jul 18, 2010
    Power light acts normally. Comes on when I push the power button, no blinking, and off when pushed again.
    Rick
    P.S. I have some knowledge of electronics. I am a Ham and I have replaced the convergence amps in this set.
  • Shahid Electronics
    Shahid Electronics Jul 18, 2010
    OK, you need to have service manual copy in hand to check power supply output voltage for horizontal output section (it calls +B), schematics in service manual will help you.
    Forgot to mention, required service manual Toshiba 57H82 can be downloaded from HERE for small fee, please make sure that your tv model is 57H82 as its being shown on question header.
    If tv model number is different, let me know.
  • rawkdw2000 Jul 21, 2010
    Of the 11 pico fuses on the board 6 were ok 3 were bad and 2 I can't get to without removing the board. Not sure were to check for +B
    Shahid Electronics Jul 21, 2010
    If you got service manual then check +120V (+B) that goes to flyback to drive horizontal deflection section, and yes, replace all open (blown) pico fuses.
    There's no place to check voltage to flyback unless I remove circuit board. Unless i"m missing something.
    Yes, tv chassis will need to be taken out from tv cabinet and turn it so you can easily see circuit boards to test voltages.
  • rawkdw2000 Jul 22, 2010
    How do I remove high voltage wires from flyback without killing myself? Will they just pull out or is there a lock of some kind?
    Shahid Electronics Jul 22, 2010
    High voltage wire can be unplug from high voltage block that has similar wires coming from three picture tubes. Press wire end and rotate it 45 degree to unlock then pull it out.
    Caution: DO NOT turn tv while high voltage wire is out. That will give you high voltage electric shock or its spark might burn other parts in tv. TV can only be turned on if high voltage wires are intact properly in high voltage block.
    Caution: DO NOT turn ON tv while high voltage wire is out.
    I also noticed 2 of the blown fuses feed the convergence amps.
    OK, replace these 2 fuses and if they blow again that means convergence output chips are defective and will be replaced.
  • rawkdw2000 Jul 26, 2010
    Parts Ordered.
    Shahid Electronics Jul 26, 2010
    Great, I'm sure you will fix it.
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My sound is muffled, since we put an hdmi cable on to fix the terrible picture, now we have a sound problem
This tv isn't known for sound problems. First thing to do is to go to the cable box and push the volume up button on the box if there is one. Next thing to do is to try another device that has a hdmi output like a dvd or game system in place of the cable box. My guess is that this muffled sound is somehow caused by the cable converter box. You can try to reboot the box by unplugging the power for 30 seconds, then plugging it back in. If all else fails, you can call the cable or satellite service and have them change the converter box. Good luck, Russmann.
Mar 24, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Hello, all of a sudden the tv made a fizz out sound
Souns like bad HV transformer. Remove thedeflection board and send it to PTS for rebuild. At this point there are also other components that have failed.
Jan 12, 2010 | RCA D52W23 52" HDTV CRT TV
Dead polaroid model 2700 visionquest tv
Your power supply has failed; have it replaced
Jan 16, 2018 | Televison & Video
No picture or sound
What model number is your set?
Feb 25, 2008 | Televison & Video
No picture or sound
You can unplug the tv from the wall for 30 min. and plug it back in to see if this will fix it. If it dosen't a repair tech will need to fix it.
Feb 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
No Picture / No Sound
What was happening before can put you close to what when out. If you had color problems or sound, or even picture going small. these are symptoms that causes the set to go out. If color look in the convergence area and look for blown fuses and bad resistors. If just went out the look at horizontal output transistor.
Aug 24, 2007 | JVC AV-48WP74 48" Rear Projection...
Spongebob tv SB314 no picture or sound
It's very likely junk and would cost far more to repair with labour than to buy a new one. Sorry to be the bearer of bad news.
Aug 07, 2007 | Emerson SpongeBob SquarePants TV
My Screen doesn't work
You can not find where the noise is coming but a service technician will know where to look and what to check.Get an estimate.
Sep 01, 2006 | Sony KV-27FS12 27" TV
Toshiba 57H82 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
