Question about Whirlpool Duet GHW9150P Front Load Washer
My duet dryer acts like it is working fine but it will not dry anything, even though it gets hot
  • rbkpgn Jul 16, 2010
    Thank you, the hose out side was stopped up and had water in it. got it cleaned out. hopefully this did it. again thanks
    Brigadier General:
  • 3,917 Answers
Have you tried drying a load with the vent disconnected from the dryer? Pull the lower panel off and then also pull the lint housing off.Both parts have 2 1/4 screws on them. Vaccuum everthing out will also help with airflow.Those units have a t-stat above the flamechamber and if the vent has poor airflow it will short cycle off on this t stat. Always vac out this dryer.Run this with the vent hose off of the dryer, if not do so as a test to see if your house vent is clogged. If you did do this suspect the thermister.
Thank You for contacting Fixya. Please let me know if you need further help else please accept the resolution.
Posted on Jul 15, 2010
    the hose from the house was packed. we got it unstopped but now the dryer says locked and I don't remember how to get it unlocked
My dryer works fine but the only prob is that it dont get hot enough to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 15, 2010 | Frigidaire FER311FS Electric Dryer
My whirlpool duet is not drying....it is not getting hot. It appears to be drying but it is not getting hot. I have to run the dryer multiple cycles.
Check for crimp in your vent line, Check your breaker. It is a dual breaker if one side pops it will run with no heat. Check those first.
Aug 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
MY WHIRLPOOL DUET DRYER IS WORKING BUT NOT HEATING
heatman101
Jul 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Even though I use a washing powder renowned for its fragrance my clothes dont get the smell on them when washed. why is this
try adding soda crystals to the drum and putting it on a hot wash, without adding anything else to clean drum pipes ect it worked for me
Aug 24, 2009 | Whirlpool 8572546 Duet Sport Stacking Kit
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
huuum At your service!
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 11, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet GHW9150P Front Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
