Question about Black & Decker Power Inverter PI400AB
I just bought a power inverter for use with my pc.
I just bought a Black & Decker 400 watt power inverter for use with my pc. I plug it in and the red light comes on instantly. Why and what can i do to fix the problem. Is the 400 watt inverter to small????
  • acgcarpentry Jul 16, 2010
    It is my laptop. I have it hooked up through the cigarette lighter. Should i try the battery???? I did it already and the inverter didnt want to come on, but did through the lighter connection so thats where i left it. I did find out that if i plug something small into it so it comes on then i can unplug it real fast and plug in my pc real fast and it stays working. Wierd but IDK still.
  • 5,165 Answers
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Posted on Jul 15, 2010
  • Cindy Wells Jul 16, 2010
    What laptop are you using? The power supplies and chargers vary greatly. Screen size, memory and CPU affect what the power draw is. Since the inverter works with the plug on a small load and then swapping in the laptop, it is probably just above the 80W limit. You will need to connect to the battery using the clips. (Red to positive on both the inverter and the battery, black to negative on the inverter and the battery) The most likely reason it didn't come on was that one of the clips was loose or a terminal is corroded and not giving a good contact. (A fast cleaning agent for batteries is cola. Pour the cola over the posts and terminals and wait until it stops fizzing. Then wipe off the excess. A wire brush is a better choice for regular cleaning. I don't recommend the cola on the terminals of the inverter since it would be too easy to get the liquid into the inverter and short the unit.)
    If you look at the charger for your laptop, you usually will find the power it needs. (A piece of chalk rubbed over the text can make it easier to read for the uses with the writing molded into the plastic.) If the rating is in amps multiply by 115V to get the watts that the unit will use. Resistive loads are easiest for this inverter to run (lights). Inductive loads like TVs and stereos use more power than the above calculation indicates. (It's an issue of the circuitry involved.)
    I hope this helps.
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
How do you change the fuse?
Most devices like this have the fuse inside the plug that goes into the cigarette lighter. The knurled silver tip unscrews. Caution that you don't loose the spring inside.
May 19, 2010 | Black & Decker Black Decker PI100AB 100...
Can I connect vacum cleaner big one with Black & Decker 100 Watt power inveter
No,
You will need a much larger power inverter than that to run that vac...
heatman101
Apr 22, 2010 | Black & Decker 100 Watt Plug-In Power To...
How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
Feb 12, 2010 | Black & Decker Power Inverter PI400AB
I have a black and decker inverter type 1 400
First, you should be aware that the exact inverter is available for under 40 dollars all over the US. Your model is sold under several names - check out http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter .
I suspect that your INPUT power level is not adequate for the inverter to put out the 200W that the 150W charger needs. If you have low current and low voltage - then the inverter can only put out a proportionally smaller AC wattage level. You may also have a faulty voltage sensor....at the input. Once the inverter sees a low level (even momentarily), it alarms and shuts down the output until the unit is reset (turned off/back on)
Dec 28, 2009 | Black & Decker 1000w Power Inverter
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
Is this inverter powerful enough?
You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
Black & Decker Power Inverter PI400AB Logo
543 people viewed this question
Top Black & Decker Electronics - Others Experts
PNiss
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
