Question about Hotpoint Washing Machines
My hotpont wt960 has started to make excessive noise and vibration when spinning. it used to be very quiet and stable. Any ideas?
    President:
  • 2,702 Answers
Your going to hate me for this!!!!
its the drum bearings wearing out,,,not a cheep job to fix,,,,
and not only that but its going to start leaking very soon as well!
told yer! now you heat me,,, huh?
Posted on Jul 15, 2010
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Nov 20, 2014 | Hotpoint Washing Machines
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
Excessive vibration on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 09, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Hotpont washer/dryer model BWD129 It started making a loud noise for a while when spinning now it won't spin at all. Please could you advise if it would be able to be fixed? Many thanks
I would say your basket drive is broke. Only when spinning, if it was this, it makes loud noises the whole time it spins, big thumps. This may be your problem. You would have to have someone look at it or call for an estimate. It would probably need replaced.
Mar 03, 2011 | Hotpoint Washing Machines
I am getting a lot of vibration from my pump
there is a bad bearing inside that has worn out and causes vibration and excess heat, when it frees up it will spin quiet for a little then bind and vibrate again. need to replace bearing.
Jun 20, 2009 | Little Giant 2-MDQX-SC Inline Pump
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
sure..start by re leveling the unit, with a standard carpenters level.
Mar 02, 2008 | Maytag Atlantis MAV5000
Washing Machines Logo
124 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
