Question about Toshiba Sattelite A105-S2051 Notebook
On shut down, I keep getting the error message ieexplore.exe ''end now'' task box.
  • 146 Answers
Internet explorer is still running, if its not open it may be due to a virus, or it may be updating
Posted on Jul 15, 2010
How to remove a copy write protected of an mp3 player
Push ctrl+alt+delete on your keyboard to bring up Windows Task Manager. Check application's to see if your media player is listed there (for example if you were running Winamp, look for winamp in the applications). If there is nothing listed there check the processes tab for the name of your media player + ".exe". If you find it right click and click end process. If you either can't find it in that list or it does not shut down then keep the window open and follow these tasks: First know where the file is located (right it down). You can do this by right clicking it and going to properties, copy down the "c:\...\...\filename" location. From windows task manager click 'file' at the top left and click run. It should bring up a black dos program. Click the Windows Task Manager again and go to explorer.exe and end process. This should shut down whatever file is being run. Switch to the black dos program and type "del c:\...\...\filename". This should bring up a prompt where it will ask you if you are sure. If you are positive this is the right file then go ahead with the deletion. If it gives you an error then ask another question regarding booting into the dos system before windows comes up. If it does delete it (and it should except on rare occasions) then type in "windows" and it should bring back up explorer and you will be all set. Hope this works and it should work for any file that refuses to be deleted because its in use.
Apr 29, 2010 | Apple iPod shuffle MP3 Player
I keep receiving the error message that Adobe Updater is running and should be closed. I ran a search and I can't find Adobe Updater on my PC.
Hi. Just press Ctrl-Alt-Del, select Task Manager Button to open the Windows Task Manager. Go to the Processes tab, look for these image names and terminate (end process) them:
adobeupdater.exe or Adobe_Updater.exe
Close the Windows Task Manager and you're done.
Hope this helps.
Aug 29, 2009 | Adobe Photoshop CS4 for PC
Get fatal error message after installationof
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
Aug 18, 2009 | HP Office Equipment & Supplies
Displays sys error session manager initialization terminated unexpectedly status of 0xc00026c (0x00000000 0x00000000)
smss.exe is the process that manages sessions in Windows Computer. This is the session manager subsystem, which is responsible for starting the user session. This process is initiated by the main system thread and is responsible for various activities, including launching the Winlogon and Win32 (Csrss.exe) processes, and setting system variables. After it has launched these processes, it waits for either Winlogon or Csrss to end. If this happens normally, the system shuts down; if it happens unexpectedly, smss.exe causes the system to stop responding (hang).
In this case, I suggest that you start the "smss.exe" process manually from the Task Manager. You can press the "Ctrl+Shift+Esc" together to display the Task Manger window. Then, click on the Applications tab then the "new task" tab located at the bottom. In the New task dialog box, please type "smss.exe" and click OK.
However, you can also perform System Restore to restore the Windows System files to the time when it operated normally. Performing System restore will not delete any saved data however, all the installed programs after the selected restored point will be unistalled and require to reinstall them.
Jul 11, 2009 | Computers & Internet
Reset secure clock
Cause and Solution to Secure Clock Error
First thing you need to do is open up your task manager by clicking control alt delete.
Select the tab "processes." In the process tab you will see a list of programs that are currently running, if you locate a file called csrss.exe it could be a trojan virus that is blocking your subscription music from communicating with your computer properly. It also effects a lot other things including hardware, personal information, security, etc. but for this post we will keep it specificly on the secure clock error. This csrss.exe trojan/virus causes your computer's internal system to not function correctly including the secure clock.
NOW WAIT! There are two different csrss.exe files, a good one and a bad/trojan one. All windows computers have a csrss.exe file on them and this "good" csrss.exe file is need in order for your computer to run propertly so don't do anything with it until you determine if you have the "good" one or the "bad" one.
You must first determine whether the csrss.exe file that is running on your computer is the "good" one that ships with the computer (inside your systems32 folder) or whether you have the trojan/virus csrss.exe file infecting your computer and secure clock.
Since the systems32 program and the Trojan/virus are both name csrss.exe you must run a quick test to see if you have the bad one or the good one or both.
First locate all fo the csrss.exe files inside your "processes" tab inside task manager (you may have more then one). The way to tell if you have the trojan or "bad" csrss.exe is by right clicking on it and selecting "end task." If you have the "good" one then you should get a windows pop up message. If you you get the windows pop up message, do NOT "end" the task, just ex out or cancel out of it. You do not want to end the "good" csrss.exe file because it is needed in order for your computer to work properly. If you "end task" on the good csrss.exe file then your computer will instantly crash (since it is needed to run).
If when you right click on the csrss.exe file and select "end task" you do NOT get a windows pop up then you may very likely have the csrss.exe trojan virus. In addition to the right click test you may want to simply look at where this file is located. If it is in your systems folder it is the good one, if it is anywhere else it is propably the bad one.
The trojan/virsu version of this csrss.exe file interferes with many of the communication hardware,drivers, software, security, etc., including rhapsody and will prompt this secure clock error message.
The only way to remove this csrss.exe trojan is to perform a system recovery on your computer returning your computer back to the original manufacturers settings. There is no way to clean, delete or remove this file trojan, you must perform a complete clean of your system by doing a system recover.
If you cannont determine whether your csrss.exe file are good one or bad ones simply back up your files and software and do a system recovery anyway, your rhapsody and mp3 player will then work fine.
May 21, 2009 | Coby MP-705 Digital Media Player
Sometimes when I try to open Outlook 2003 in the morning after shutting it off the night before (but leaving the machine in sleep mode), it looks as though it is opening but never shows up and all I see is...
Outlook is actually running in your system.Do following steps.
Press Shift+Ctrl+Esc -> You will see the windows task manager.
In application tab you can see Outlook task.If its status is showing 'Running'. Then select that outlook task and click on Switch o.Outlook should open now.
And is Status of the task is showing 'Not Responding' or you cant see the outlook task then go in 'processes' tab.In this you will see a process named 'Outlook.exe',select that process and click on ' end process' and then reopen the outlook.It will work.You dont have to restart your machine every time.
And also do repair outlook.for this open outlook and click on help tab and select detect and repair' option.this will repair your outlook.
Mar 31, 2009 | Microsoft Outlook 2003 for PC
Zunesetuppkg-x86 is not a valid Win32 application
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Feb 24, 2009 | Microsoft Zune JS8-00001 Digital Media...
I m unable to shut down my inspiron..............every time i does it , it gets stuck......& i have to shut it down by power button......plz help me out
You have a process that is not shutting down,Try this,Hit control,Alt,Delete and open the task manager,On the process tab,you can see what is running,End task on everything BUT Explorer.exe,logon.exe,and The svchost.exe(you will have a bunch of these)After you have end task on everything else,Try and shut down.
Jan 06, 2009 | Dell Inspiron 710m Notebook
Mio digi walker 220
application MioUtility,exe has performed an illegal operation and will be shut down. if the problem persists, contact the program vendor
program:MioUtility,exe
Exception:0xC000000D
Address:8C06DF8C
Mar 20, 2008 | GPS
Toshiba Sattelite A105-S2051 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
