wont crank? Check fuses first? (USA answers)
use the scan tool and get P1500" starter signal dead?
which engine, 1.6L or 1.8L which trans, A/T or M/T (auto./stick)
did you try cranking in Neutral (guessing A/T)??
the relay with 2 white wires, it is.
the USA left drivers side fuse box. is WHERE it is.
if you hot wire the starter and it cranks its, ok the starter
if car cranks in Neutral the PRNDL switch is bad.
if the relay below has 12vdc on coil or 11v, cranking
voltmeter across coil and output contact is dead the relay is bad.
if no 12v across , that means bad key line (PNRLD) or bad ignition switch, (hot wired starter works, is base line 1st test)
