My FSP20060SAV when i turn On my pc they have power but they have no display in my monitor
  • 146 Answers
Switch the monitor on/plug it in
Posted on Jul 15, 2010
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Monitor does not come on when laptop is switched on
This issue could be due to presence of static charges on the notebook or hardware malfunction of the display screen or defective video card on the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists, then connect an external monitor to the notebook and check for the issue on it.
Step 2: External Monitor
You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is covered under the HP warranty, then I would suggest you to contact HP to get the notebook repaired under warranty from HP.
Jun 01, 2010 | HP Pavilion dv9000z Notebook
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
Step 2 :External Monitor
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
May 20, 2010 | HP Pavilion dv6000z Notebook
I have hp dv6500 i update my bios and my display is total black just light blinking pls help me wht i do ?
This could be due to hardware malfunction of the video card on the notebook. To isolate this, perform the following steps.
*** Hard Reset ***
After performing the above step, if the issue persists, then connect an external monitor to the notebook and check if the display comes on external monitor or not.
*** External Monitor ***
When I turn on My HP Laptop the system start booting and all of the lights on the laptop turned on but the screen doesn't display a thing it is always dark could anybody help me... Thanks in advance...
This could be due to presence of static charges or hardware malfunction of video card or defective LCD display screen of your notebook. To isolate this issue, perform the following:
HARD RESET
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists then connect an external monitor to the notebook and check if it works fine. You can follow the steps listed below to connect an external monitor to the notebook.
May 18, 2010 | HP Pavilion dv1000 Notebook
No display everything turns on windows loads but no display
We can further isolate the issue by connecting an external monitor to the notebook. If the display is fine with the external monitor, this clearly indicates that the issue is related to the LCD screen. Otherwise, it is due to the some other internal hardware.
You may follow these steps to connect the notebook to an external monitor.
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
External monitor.
May 14, 2010 | HP Pavilion DV9620US Notebook
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    The monitor shuts off. Turning the power off
    the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
    Aug 08, 2009 | Princeton Digital Computers & Internet
    HP desktop monitor problem
    hi try this ,,,
    1. Ensure the video cable is connected (and connected to the correct video port).
    2. Turn off the monitor using the monitor's power button and then restart the monitor.
    3. Cycle the power on the monitor as follows:
    4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
    5. Unplug the power cord.
    6. Wait 5 seconds.
    7. Plug in the power cord.
    8. Press the power button on the monitor to turn on the monitor. One of two things happens:
      1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
      2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
      3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
        • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
        • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
        hope it will work for u .. little_angel
    Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Compaq monitor no working properly
    Did monitor work's on another pc?
    If YESS so u need to change ur VGA
    Nov 02, 2007 | Compaq Presario 5000 PC Desktop
    Computers & Internet Logo
    David Payne
    David Payne
