How to change a ballast on 61" rca tv dlp - Televison & Video
  • 484 Answers
First of all, get the appropriate screwdriver, then you open up the cover of the television.
Open up the television. By the panel you will see the ballard and where it is connected.
Then you can carefully disconnect the ballast and replace it with the new one you got for it.
Ensure the capacitors are working perfectly fine before replacing the ballast because the problem might be from the capacitor. If the capacitor connecting power to the ballast is faulty, the ballast will not work.
Intermittent shut down can be caused by a bad lamp so i will advice you check it as well.
I hope my assistance was helpful.
Take care
Posted on Jul 15, 2010
  • Sergio Silva Jul 16, 2010
    I'm sorry but I need more information where is it located, how does it look like? how close to lamp is it? and any other information that you may see pertinent.
How do i find the ballast in rca dlp tv
I just had an issue with my rca hd61lpw42, I had replaced the lamp and got the same five blinks you described. I took out the ballast the smaller circuit board, its in front of the light and mounted to the front of the tv. To get to it you remove the back cover with the tv cooled down and unplugged of coarse. Be extremely careful when removing the ballast as it normally operates at about 336 volts dc. its basically no amps but it will still throw you across the living room. The being said I found another site that discussed our issue on the ballast going bad. It is not the whole board that is bad normally. There is a solder joint in the middle of the circuit board coming up off the bigger board and that solder joint normally goes bad and causes the issue. All I had to do was remove the board and resolder the connection and reinstall. But you can get them on ebay for $50. iif you have the money or no soldering experiance I would suggest that route. The site is http://www.ebay.com/sch/i.html?_trksid=p4712.m570.l1313&_nkw=%09+RCA+Ballast+Assembly+%28261629%29&_sacat=0
Now I hope I can keep the light tunnel together :-)
Aug 10, 2012 | RCA HD61LPW42 61" Rear Projection HDTV
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
Changed lamp in 61 inch jvc dlp and still can't get tv to turn on
Ballast board is what turns Lamp on and CK your Fans if Lamp Fan is defective TV willnot come on.
Dec 11, 2009 | JVC HD-61Z575 61" Rear Projection...
RCA HD50LPW42 Shuts Down after 30 mins
Well it seems you may have an issue with your ballast that it's losing the energy it used to have , but we would need more info for a more accurate answer about this, discountdashmerchantdotcom
Jul 24, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Feb 09, 2009 | Toshiba 32AF41 32" TV
RCA 61 DLP
See my last post to you the 5 blinks means defective lamp I included a link where you can get a replacement
Apr 25, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Rca scenium 61 inch dlp
the unit has a bad color wheel,a big pain in the ass to change.the part runs about 175.00 labor is about 200.Try first to get the manufacture to fix unit,be persistant
Mar 20, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
