Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Dishwasher water level drops during washcycle
Hi
It takes water OK, then during the cycle the water starts to run out the drainhose
After a while there is hardly any water in the machine
Waht do i have to do?
    Novelist:
    Champion:
  • 222 Answers
Check the stand pipe for the drain hose it must be higher than the water in the machine or it will just run out should be 30 inches or higher. I just worked on one with this same problem the drain was about a foot high it would fill and run out almost as fast as it came in.The pump will pump it out when it drains.
Posted on Jul 16, 2010
The soap doesn't dissolve and sometimes the plates are still dirty.
Start dishwasher. Stop after a minute or so. Check the water level in the tub. On a older model I would expect about 2 inches of water in the tub. About 1/2 inch or so below heater.
If water OK than I assume you can hear the pump running.
If pump running and enough water than I would assume a blocked wash arm.
  • First rotate by hand and make sure that it doesn't bind or interfere with rack.
  • Check carefully the holes at the ends of the arm looking for debris that collects. Seeds and such love to collect at the tips preventing the jet of water that provides the rotation force from escaping. Use small tweezers to grab debris and pull through hole
  • Blocked water return screen. Look for clear plastic etc that covers the return of the water to the pump sump.
  • Place small cups right side up in upper and lower rack. Cycle machine for a minute or so. Confirm cups are filling with water!!
If all checks OK than try running water at sink for several minutes to confirm water is very hot. Start cycle knowing inlet water to dishwasher is hot. Evaluate results.
Dec 09, 2015 | Kenmore Dishwashers
L have error code E3 on delonghi dishwasher
We have discoverd xactly why and sorted this on the bottom righthand wall there is a small circular sensor which measures the water temp during the washcycle. If you cover that with a plate pan or chopping board it cannot detect when temp reaches 47 degrees c so gets stuck on 1hr 32 min in the 2hr cycle. Keep that sensor clear and it will stop.
Feb 17, 2012 | Dishwashers
F8 flashing unit will not cycle gets water then starts beeping
F8 - this code is indicated that there is your dishwasher is having problems detecting the correct water level. Often this results from an insufficient amount of water entering the dishwasher during a cycle - so the water supply is probably ok but check it as F6 (F6 means that the dishwasher is unable to fill with water. Ensure that the dishwashers water supply is turned on (double check the tap valve to make sure its open). As above, also make sure that the inlet water hose is not obstructed, kinked or twisted), just in case.
Occasionally the water level sensor might misread if there a too many bubbles in the dishwasher (i.e. if you put washing-up liquid in the machine, etc).
Otherwise your machine may be having an issue with water pressure, possibly caused by a faulty water pump.
Hope this helps.
Jun 03, 2011 | Bosch Dishwashers
I have a Bosch Exxcel dishwasher which runs the drain pump constantly even with the door open and despite there being now water in the machine at the cycle wont start. I have checked the warer amtrix and...
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
Jun 30, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Dishwashers
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
