Question about Raritan Icer-ette Ice Cube Maker
Unit runs but no ice.in searay boat fan does not want to come on. Unit runs. .Live in chatham ont. canada. what to do. dave @beams56@yahoo.com
My unit turns on works for a while then shuts down, fan would not re-start every cycle, causing over heating and shut down, cleaned the fan, oiled the bearings, cleaned all the elec. connections, seems to work now.
Posted on Aug 02, 2010
I have a 2000 210 Searay that the trim button will not raise the outdrive. I have to use the trailer button to trim it
The trim button is specifically designed NOT to raise the lower unit past the level the unit should be trimmed up under power. There is an "over ride" switch somewhere on the dash, or the engine control unit, that has to be used AT THE SAME TIME as the trim switch to move the out drive up past what the manufacturer considers "safe" while under power! Look around.... You will find it, but remember it MUST BE USED AT THE SAME TIME AS THE TRIM "UP" SWITCH!
Jul 17, 2017 | Boating
What is the fuel capacity of my 1994 Sea Ray Laguna 18' Center Console boat?
I found spec sheets only for two boats from 1994 that are 18'. Both say they have 30 gallon tanks. http://www.searay.com/boat_graphics/electronic_brochure/company1729/1C1_27_74DERNQMC747.pdf
Aug 02, 2016 | Cars & Trucks
How do I find the postal codes for chatham Ontario?
Enter complete address, including unit number, into the box on the Canada Post website:
http://www.canadapost.ca/cpo/mc/personal/postalcode/fpc.jsf
Feb 16, 2015 | Computers & Internet
I am getting power and the freezer appears to be working but the fridge is not cold at all, any suggestions? Many thanks Dave McRae
Hi Dave and welcome to FixYa, I am Kelly,
Take a look in the back of the freezer compartment. Look for any signs of icing on the back access cover. Usually but not always the evaporator coils freeze up because the unit is not automatically defrosting properly or there is a problem with the evaporator fan not running fast enough / at all. Press gently with your hand of the back cover of the freezer compartment and feel for ice. Also check the front of the chassis for signs of being HOT. It is ok to be warm not hot.
Also check to see that the light goes on and off as you actuate the light switch plunger. Some units have the door switch in the top of the door hinge but most have the switch in the door fold area of the chassis some where.
If you find that the evaporator coils have iced up:
  • Perform a manual defrost of the unit but first unplugging it
  • Remove the freezer contents
  • Direct an external fan into the freezer compartment for just over 2 hrs. (makes a water mess)
  • After 2 hrs clean up the water mess and return the unit to normal service.
  • Watch after 3 days if the fresh food compartment once again starts warming up. If it does you have and automatic defrosting problem.
No ice noted:
  • Possible temp control problem (Thermostat / cold control or thermistor)
  • Possible Air Damper problem. There are 2 kinds of air dampers. One is electrically controlled and the other is nothing but a mechanical baffle that is positioned partially open. If you have the electrical type the air damper motor may have failed or the movable baffle is stuck.
Front of chassis is almost HOT to the touch vs warm:
  • Open the back of the unit by removing the black fiberboard cover and inspect for lint and that the condenser fan is running anytime the compressor is running.
Light always on:
  • Door switch failure. Some door switches also control the evaporator fan along with water in door and ice in door functions. The water and ice in door should NOT work with the door open.
The above is pretty much an in home repair techicians check list for the symptom you describe.
If you discover that you have an automatic defrosting problem I will need you MAKE & MODEL number via your next response here so I can tell you what you can do to troubleshoot. (
Thanks for choosing FixYa,
Kelly
Feb 28, 2011 | Microwave Ovens
U line ice maker on boat
If this is a stand alone icemaker. Is the unit running? If not check the icemaker ejector blades to make sure that its pointing at 12 oclock. If not then you need to take the cover off the icemaker and turn the smaller gear counter clockwise.(remove cover by gently prying on the inside corners and pull at the same time) Turning it counter clockwise will turn the ejector blade. Once you get it to 12 the plug the unit in and turn on. Compressor and fan should come on. If the unit is running then make sure the fan is operating. Yes then is the compressor on? Yes > then you have a sealed system problem. Let me know if you need further assistance.
Jun 17, 2009 | U-Line Icemaker
LOCATING PARTS FOR HOOVER UPRIGHT
What is you rmodel number????
Jun 21, 2008 | Vacuums
Goodman CKL60-1L
Four things cause icing up:
( 1 ) Is your filter clean? dirty filter blocks air flow causing iceing up. replace filter
( 2 ) Do you hear the Indoor fan running? If the fans not running the unit ices up. Check Capacitor to fan if good.
Bad fan motor... replace fan motor and cap. If both good
( 3 ) Check Air Handler evap coil if dirty and or clogged, restricts air flow causing unit to ice up. Use toilet brush to clean.
This is always a big possibility if you have pets.
( 4 ) If the above are not present then you are low on refrigerant.
Low refrigerant will cause icing up because the gas does not flash properly. This will require a service tech.
refrigerant leaks can be as simple as a loose cap on the king valve, leaking schrader core, to coil leak.
Have the service tech show you the leak. If it is in a copper line it can be fixed. If the system is over 10 years old limit the amount you want to spend. 10 years is the standard life expectantcy anymore. Good luck
May 20, 2008 | Goodman CKL60AR60 Air Conditioner
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
Raritan Icer-ette Ice Cube Maker Logo
276 people viewed this question
Top Raritan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Raritan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
