Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Ran great, set up 2 days and won't start, engine will turn over.
It is a dls 3500 20 hp Briggs engine, 46 cut
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
How do I set the valves,what is the setting .020?
No a lot closer to .005 but need the engine info to give the correct setting. .020 will definitely cause the decompression to become non-operative.
Apr 10, 2015 | Craftsman 46" 21hp Briggs & Stratton Turn...
I have a Craftsman DLS 3500 Briggs and Stratton 20 HP, When I engage the cutting blades the engine dies.
first, is this with or without the brake pedal released ??? I would check the seat switch first. Then, if you have an 12 volt blade clutch ( push/pull switch on dashboard ) then I would check it next.
Oct 20, 2013 | Garden
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Gas ran out of sparkplug hole
If you had raw gas in the cylinder to where it poured out of the plug hole you most likely have a carburator problem. Inside the carburator is a float and needle, the float pushes the needle into a seat when the bowl is full of gas so no more gas will flow into the bowl or the engine. If the float won't float or the needle is damaged or has dirt between it and the seat the gas will continue to flow into the carburator and on into the engine. If enough gas gets into the cylinder the starter won't be able to turn the motor over. You should also check your oil, usually when gas gets into the cylinder it runs into the crankcase and thins the oil to where it will damage the motor if run for any length of time.
May 09, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
176 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
