Question about Canon imageRUNNER 5000 Copier
Copying problems I am using a Canon Imagerunner 5000 series copier and I am trying to copy a book that is almost 11 x 17 to a 8.5 x 11 double sided copy that has enough margin to be able to add holepunch but doesn't cut words off. HELP!!!!
  • Canon Expert
  • 287 Answers
Hi Beckybuzz,
I have couple of ideas for ya. But I assure you I can help. First thing is to merely reduce the image slightly by about 4%. OR, you can go into "additional functions" and alter the x and y coordinates whicj allows you to skinny or stretch the image from top to bottom or (in your case) left to right. You can also do an "image shift" which was designed specifically for a 2 sided finished document. All kinds of goodies are available under the additional functions tab. I am sorry I don't have the op panel in front of me , but I believe you will be fine because of the intelligent manner of which you aked the question. But please, by all means feel free to ask back if I can help more. Take care and GFL.!..........................................SPINAL>>>>>>>>>>>>>>>>>
Posted on Apr 22, 2008
Cannon fax machine
try to look the gears on your upper roller and all those connected on it, it might be broken
Jun 11, 2013 | Canon imageRUNNER 5000 Copier
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
The canon runner s5000
1)u must verify which location of the first paper jam occur.
2)pick up unit > feeding >fuser unit> output delivery unit.
3)try to use platen glass for copying instead of using the auto document feeder unit.then u can narrow down the issue.
Sep 11, 2009 | Canon imageRUNNER 5000 Copier
Does not start say on display --is E000532-0002
It's a finisher error try copying or printing with deatach the finisher
The stapler unit does not return to home position when the stapler
shift motor has been driven for 4 secs.
Feb 26, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
I am receving error code Eoooo64
i have canon irc2100. colour dust is also printed with the material on the page, plz send me solution
Sep 30, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Photocopying a book
yes, there is a button for book form.
it will either be in additional functions or duplex mode.
when copying leave book open on glass it will scan the first page then scan the other page. you can have it on two different sheets or one double sided sheet.
Good luck.
p.s.: it should be in the user manual also if you have it.
Nov 15, 2007 | Canon imageRUNNER 5000 Copier
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 5000 Copier Logo
111 people viewed this question
old marine
old marine
