Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
WHAT SIZE SOCKET NEEDED TO REMOVE ANODE ROD?
What size socket is required to remove anode rod from GE electric water heater model SE40M12AAh?
  • 455 Answers
Hello EDAN I believe it is 1 1/16" socket.I had 1/2" drive & extention bar as it very TIGHT & hard to turn the rod nut.
Posted on Jul 16, 2010
Where is location for anode rod?
The anode rod on a hot water heater is usually located on the top. There's usually what looks like a bolt head that you can undo with a wrench to remove the rod. It will be directly on the hot water heater and won't be part of the water lines running in.
Nov 24, 2015 | Water Heaters
Why is there a bad odor from my 19.9 gallon reliance electric hot water heater
Anode rod?
Replace anode rod, or remove anode rod, and clean tank with hydrogen peroxide (not bleach)
Anode will keep tank from rusting.
Cut new anode rod to correct length using hack saw.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
Aug 25, 2014 | Water Heaters
Rusty smelly hot water
The rust can be from rusted pipes, and not necessarily tank:
New tank has new anode rod, and is NOT likely to be cause of problem.
Anode only protects the tank... not your steel pipes.
There are mathematical formulas for figuring what size and type anode is needed for steel structures like bridges and water heater and boat hulls... if anode is too small or deteriorated, or coated in calcium, or not electrically bonded to the steel surface, or if tank is not full of water or boat hull is out of water, then anode cannot protect the steel.
For more insight about problem:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Gene h
Mar 20, 2014 | Premier Water Heaters
GPS-75-200 anode replacement
The anode is located under the power vent.
Remove power vent to gain access.
Otherwise, remove Hot water nipple and install combo anode rod. If odor is the reason for replacement, then installing a combo without removing the old anode will not solve odor problem until old anode completely dissolves over time.
Copy following link for specific information and illustrations, including odor elimination using hydrogen peroxide.
For easy access next time, you can remove old anode and plug hole, and then install combo rod.
If longevity of tank is reason you are accessing the anode, you can add a second combo anode in addition to the original anode and give longer protection
Aug 07, 2012 | RTO W4 A.O Smith Gas Hot Water Heater...
Where is the anode rod located on the rheem 81VP20s
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
http://waterheatertimer.org/pdf/Rheem-Ruud-anode-rods.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
http://waterheatertimer.org/images/Water-heater-anode-006-200.jpg
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Hot water has strong organic odor noticeable at all outlets but mostly, of course, at shower head.
It sounds like you need to replace the anode rod on your water heater. They come from the factory with a magnezium rod to slow down electrolytic deteiroation. With the odor you are getting you probably have a high sulphur content,,I think the proper terminology is suspended sulfides,I guess it doesn't matter what you call it it stinks. You can replace the magneziun anode rod with one made out of aluminum to help with this problem. Hope this helps you. Thanks. P.S. anode rod is screwed into the top of the water heater and has a hex head so you can use a box end wrench or socket to remove and reinstall. You can also use hack saw to cut rod to lenght needed to fit. Thank you.
Feb 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
How do I Remove Magnesium Anode ?
The following page has instructions and a link to a video:
How to:
Rods are installed in top of tank.
Most are located under a 2" round plastic cover located on top of tank.
Some anode rods are connected to hot water nipple
Read owner's manual to see location of anode rod
See list of water heater manufacturers and brands to find product manual.
Before starting, turn off heater source: electric water heater: turn off circuit breaker; gas water heater move control knob to pilot.
Close shutoff valve on cold water side of water heater
Open bathtub faucet to relieve pressure and let air into water line.
Open drain valve near bottom of tank,, and drain 2 gallons of water.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Use 1-1/16" socket for hex head rod
Rod will be rusted in place, use generous amount WD-40
WD-40 spray is flammable and will burn so be careful around heat source.
Loosening rod: go slow and check that water does not seep up when loosening rod because hot water can spew out hole if tank is very hot ... it is important to drain enough water out of tank to avoid accidental scalding.
Install new anode rod: One source says/ use pipe compound on thread instead of teflon tape. Other sources say use teflon tape. Either way, tank metal and anode metal must meet, so rod will work.
Dec 23, 2010 | Water Heaters
Does the 501 ahve an anode rod. If so, how do I replace it
Every water heater has an anode rod.
Reliant manuals
http://www.reliancewaterheaters.com/lit/om.html
Reliant is made by American
I don't find a 501 manual under gas water heaters at reliant.
The Reliant manuals that are available do not show the anode rod in the drawing.
But they do show an access port on top of tank.
The anode rod is usually under the access port which is a round plastic disc.
On some water heaters, the anode rod is under the steel top and you have to remove the screws holding the top on.
Some water heaters, the anode is connected to hot water outlet.
Below are two links for the do-it-yourself-er
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
Oct 23, 2010 | RELIANCE ELECTRIC WATER HEATER
Annual maintenance for Rheem water heaters calls for removing and checking the anode rod. After some searching I found a 6-point 1-1/16 socket, but I can't turn the anode rod. Applying more leverage...
PROBABLY. THE ANODE PROBABLY FUSED ITSELF TO THE TANK VIA ELECTROLYSIS. I WOULDN'T WORRY ABOUT INSPECTING THE ANODE ROD UNLESS U LIVE IN AN AREA OF HARD WATER AND/OR THE UNIT IS OVER 5 YEARS OLD. DRAINING AND FLUSHING THE WATER HEATER TWICE A YEAR WILL HELP KEEP THE UNIT PERFORMING LONGER. ADDING A WATER HEATER BLANKET WILL HELP LOWER UR UTILITY BILL AS WELL.IF U FEEL U MUST HAVE AN ANODE IN UR TANK, ANY RV DEALER HAVE ANODES FOR A SUBURBAN WATER HEATER THAT U CAN ADAPT AND THREAD INTO THE DRAIN PORT OF UR WATER HEATER.
Dec 06, 2009 | Water Heaters
Removing anoide.
You will need to turn off water,electric.Release psi.and look at the middle of water heater and you will see a big bolt like thing.You will need a big wrench or socket to remove it.
Mar 15, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
1,492 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
