Question about Cub Cadet Street Sign- tractor lawn riding mower parts
1872 cub cadet. Pto keeps turning off. Will mow a few minutes then blades shut off
Check your battery posts and terminals, they may be corroded, or your battery may be dying.
Posted on Jul 23, 2010
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
Jul 24, 2014 | Cub Cadet Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Was mowing-blades just quit turning-pto will not engage
Belt has broken, or jumped off the pulley, or jumped off the belt tensioner. Look at your deck and go from there. You may have to remove your deck to get to the belts under there cvers but you will see your problem.
Jul 03, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My cub cadet 2165 PTO clutch has no voltage getting to it to activate it. the normally closed switch is ok. could it be the relay? how do I test it?
on my cub the blades keep shutting down when im mowing . I replace the pto switch and it doesnt help .. got a recommendation
Feb 03, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
577 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
