Condenser fan motor runs constantly compressor stops but fan still runs
  • 57 Answers
Don't know what type of unit you're talking about but usually there's a relay or contactor to turn the fan on and off. Sounds like it may be stuck closed. The points may be pitted. Best to change.
Posted on Jul 16, 2010
Intertherm MGHA-070ABFC-05 will not run/cool
Multiple problems. Eliminate thermostat first. Remove face from wall and turn on breaker. If fan still runs you have a bad board or bad relay. If fan outside is running compressor should be too. These operate on same contactor. Verify you are getting 24 volts to coil side of contactor. If odf stops working and contactor remains pulled in you have a bad motor. If odf motor stops working the compressor will shut off due to overheating.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 07, 2016 | Intertherm Heating & Cooling
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
The capacitor was bad and was replaced. now the system will work fine for about 30 min then the fan the outside unit will stop working. it sounds like the compressor is still on and cold air is will...
Yes, if you changed the three post capacitor that runs the fan and compressor, and the fan is still getting hot and shutting down until it cools off, you may have bushings out of the motor or an internal short. Sounds like you have a job ahead of you of changing your condenser motor. If you do this yourself just contact me I will step you through it . Mark
Jul 10, 2011 | Goodman CLJ36AR42 Air Conditioner
Freezer cuts on every 3-4 minutes. stays on 8-10 seconds. some thawing occuring
If I understand you correctly the compressor is short cycling. The more it does this the worse it gets by causing the compressor to overheat. Sometimes the problem is because the condenser fan or evaporator fan being defective. Pull away from wall and remove cover over compressor unplug and feel top of compressor and if too hot to keep hand there keep unplugged but do examine the evaporator and condenser fan to eliminate them as a reason. The most likely reason is start relay and or start/run capacitor and sometimes a worn out compressor.
Overload relay click here=> 67002527
Run capacitor click here=> 65889-4
Location Click Here=> MBB1952GR Compressor Components
Parts in that photo are marked as 10 overload/relay, 11 is the run capacitor and 3 being condenser fan motor. Condenser and evaporator fan motors do not always stop completely when bad so make sure both run while compressor is running. If this has been helpful please rate if you have more questions please let me know, Thanks Sea Breeze
Dec 10, 2010 | Maytag MBB1952GR Bottom Freezer...
I have a ge gss20iemdww - 20 fridge. The fan inside the freezer is always running and it does not freeze anymore, but its still cold. I already replaced the mother board it did nothing.The condensor fan is...
I owned my own appliance repair shop from 79 to 90. Haven't done it since. However, I will attempt to help you with this.
Makes cold but not freezing, freezer fan is running.
The items that will give this issue are multiple.
1. Low refrigerant ---- not likely
2. Weak compressor --- more probable but not likely
3. faulty compressor overload protector --- more probable but not likely
3. dirty condenser or bad condenser fan motor.
These cause high head pressure and mess up the cooling cycle. The compressor may be going off on a temp protector or it could be running constant. You will need to remove the back panel to see these items.
If it is a dirty condenser that is causing this it will be REALLY dirty. You will know.
If it is the condenser fan it can be blocked by something, normally a dead mouse, or something that was dropped in front of the refrigerator and carried by the air flow of the fan. Not so likely. Don't rule this out if you don't see it in the fan as sometimes things shift when you move the appliance. It doesn't take much to stop these motors as they are very low wattage.
Dec 21, 2009 | GE Refrigerators
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
My refrigerator constantly runs and is not cold enough. Could it be the control temp?
THE CAUSES FOR THE PROBLE4M OF LOW COOLING MAY BE
  • Freezer fan and its circuit problem.
  • Defective fan motor.
  • Defective defrost timer,defrost heater or defrost terminal thermostat.
  • Temperature control failure.
  • Compressor motor defective. Inefficient compressor (low wattage readings).
  • Condenser fan.AC circuit to fan open (high wattage reading). Defective fan (high wattage reading).
Aug 19, 2009 | GE Refrigerators
Fan / Compressor runs constantly
Condenser fans (the fan next to the compressor) do run all of the time. That is normal.
Sep 18, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
